2016 CRV valve adjustment
I will be performing a valve adjustment on my 2016 CRV with K24W9 Earth Dreams engine. I have spent this morning researching HondaTech and the internet for the jam nut torque value and the valve clearance. I find other K24 engine values, but not for the K24W9 engine. Perhaps they are the same? I found a torque value of 14 lbf-ft on intake valves and 10 lbf-ft on the exhaust valves. And 9 - 11 mm on the intake valves and 11 - 13 mm on the exhaust valves. are these values correct? Thanks your for time.
Valve Clearance
Intake:
0.21-0.25 mm (0.009-0.009 in)
Exhaust:
0.25-0.29 mm (0.010-0.011 in)
Locknut Specified Torque:
14 N·m (1.4 kgf·m, 10 lbf·ft)
Apply new engine oil to the nut threads.
Intake:
Exhaust:
I am sorry for questioning you, I want to make sure because older models of K24, had same valve clearance, if I am not mistaken. But K24W9 is with direct inject, unlike the older ones, so the clearances might be different.
Are the numbers above applicable in particular for Honda CR-V 2018 motor K24W9?
Sorry if it is a stupid question, but how/where do we apply new engine oil to? we are loosening and tightening the locknuts right? or does that only apply if we are replacing the bolts?
LoudAccord
Mar 25, 2002 02:05 PM
