2016 CRV valve adjustment
I will be performing a valve adjustment on my 2016 CRV with K24W9 Earth Dreams engine. I have spent this morning researching HondaTech and the internet for the jam nut torque value and the valve clearance. I find other K24 engine values, but not for the K24W9 engine. Perhaps they are the same? I found a torque value of 14 lbf-ft on intake valves and 10 lbf-ft on the exhaust valves. And 9 - 11 mm on the intake valves and 11 - 13 mm on the exhaust valves. are these values correct? Thanks your for time.
Re: 2016 CRV valve adjustment
Valve Clearance
Intake: 0.21-0.25 mm (0.009-0.009 in) Exhaust: 0.25-0.29 mm (0.010-0.011 in) Locknut Specified Torque: 14 N·m (1.4 kgf·m, 10 lbf·ft) Apply new engine oil to the nut threads. |
Thanks again Tech8. Your responses are quicker than a hiccup. To verify, the maximum intake valve clearance is 10 mm?
0.25 mm, not 10 mm.
My mistake. I was referring to 0.010 in. for the 25 mm maximum intake valve clearance.
Originally Posted by tech8
(Post 52434184)
Valve Clearance
Intake: 0.21-0.25 mm (0.009-0.009 in) Exhaust: 0.25-0.29 mm (0.010-0.011 in) Locknut Specified Torque: 14 N·m (1.4 kgf·m, 10 lbf·ft) Apply new engine oil to the nut threads. I am sorry for questioning you, I want to make sure because older models of K24, had same valve clearance, if I am not mistaken. But K24W9 is with direct inject, unlike the older ones, so the clearances might be different. |
Originally Posted by bambuk
(Post 52821384)
Are the numbers above applicable in particular for Honda CR-V 2018 motor K24W9?
10mm ? Wow I bet it would not back off that far. :o
