Honda CR-V & Element 2WD & 4WD Element & CR-V
2016 CRV valve adjustment
Old 06-19-2021, 09:02 AM
brownbeardad's Avatar
Default 2016 CRV valve adjustment
I will be performing a valve adjustment on my 2016 CRV with K24W9 Earth Dreams engine. I have spent this morning researching HondaTech and the internet for the jam nut torque value and the valve clearance. I find other K24 engine values, but not for the K24W9 engine. Perhaps they are the same? I found a torque value of 14 lbf-ft on intake valves and 10 lbf-ft on the exhaust valves. And 9 - 11 mm on the intake valves and 11 - 13 mm on the exhaust valves. are these values correct? Thanks your for time.
Old 06-19-2021, 09:38 AM
Global Moderator
tech8's Avatar
Default Re: 2016 CRV valve adjustment
Valve Clearance
Intake:
0.21-0.25 mm (0.009-0.009 in)
Exhaust:
0.25-0.29 mm (0.010-0.011 in)
Locknut Specified Torque:
14 N·m (1.4 kgf·m, 10 lbf·ft)
Apply new engine oil to the nut threads.
Old 06-19-2021, 11:11 AM
Thanks again Tech8. Your responses are quicker than a hiccup. To verify, the maximum intake valve clearance is 10 mm?
Old 06-19-2021, 12:17 PM
Global Moderator
tech8's Avatar
0.25 mm, not 10 mm.
Old 06-19-2021, 03:53 PM
My mistake. I was referring to 0.010 in. for the 25 mm maximum intake valve clearance.
Old 04-14-2024, 06:27 AM
bambuk's Avatar
Originally Posted by tech8
Valve Clearance
Intake:
Exhaust:
Are the numbers above applicable in particular for Honda CR-V 2018 motor K24W9?
I am sorry for questioning you, I want to make sure because older models of K24, had same valve clearance, if I am not mistaken. But K24W9 is with direct inject, unlike the older ones, so the clearances might be different.
Old 04-14-2024, 09:31 AM
Global Moderator
tech8's Avatar
The valve clearance is the same for the 2018 2.4 motor.
Old 04-16-2024, 12:53 PM
chidog's Avatar
10mm ? Wow I bet it would not back off that far.
STATek9
09-18-2009 08:47 AM
spriddle
12-16-2008 04:02 AM
Bulli Kid
12-08-2007 07:04 PM
kornerk12
12-18-2005 03:27 PM
Quick Reply: 2016 CRV valve adjustment
