B swap iv tried everything
Old May 23, 2021 | 05:00 PM
Stan Bradshaw's Avatar
Default B swap iv tried everything
What’s up guys so iv got a 97 civic ex that I’m in the process of finishing a b18b1 swap into the car originally was a automatic d16y8 the car was manual swapped way before I started the b swap the b18 is freshly rebuilt new rings bearings pistons oil pump water pump timing belt starter clutch and flywheel spark plugs ground wires iv got an obd1 ecu that’s basemapped for a b18b1 in it right now it’s getting good spark it’s getting fuel it’s got the stock intake manifold everything hooked up correctly iv gone over this car 3 times and I can not figure it out for the life of me I redid the mechanical timing just to verify that it was in time when it cranks it sounds healthy just like a normal b series but I can not get it to start just looking to see if anyone may have an idea as to what it is or has had the same issue iv been reading thru different forums for 2 days trying different things and nothings worked
Old May 23, 2021 | 08:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B swap iv tried everything
What fuel feed line are you using between the fuel filter and the fuel rail inlet (the one from your '97 Civic EX chassis OR the one from the Integra chassis the B18B swap came from) ?
Old May 24, 2021 | 08:07 AM
Thanks for the reply so I am using the line from the integra that goes from the fuel filter mounted on the fire wall to the fuel rail I’m getting pressure at the filter and at the rail when I pull plugs you can smell the fuel on them
ssw2559
Mar 17, 2013 10:29 AM
nemesiskrp
Apr 7, 2009 09:25 PM
bjfisher
Sep 2, 2008 08:14 PM
tatmark1
May 10, 2006 06:44 PM
alleyezonme
Apr 8, 2004 08:26 PM
