POS Wont Start
Old Aug 26, 2008 | 01:11 PM
bjfisher's Avatar
Default POS Wont Start
ill try to make this quick. i bought a 93 civic ex that sucked up water, swapped in a d15b7 i had just pulled from my brothers car to swap in a gsr. got my motor in, car wont start. crank, but no fire. i dont seem to be getting spark, and the fuel pump wont click on. the fuel pump worked when i parked the car. ive tried 3 dizzy's, 2 ECU's, 2 main relays, and new spark plugs/wires. as far as i can tell, all fuses seem to be ok. this is getting really aggrivating. any ideas are appreciated as im sick and tired of seeing this car in my garage on jack stands.
Old Aug 26, 2008 | 06:45 PM
dtapia's Avatar
Default Re: POS Wont Start (bjfisher)
check the ground wire g 301 on the t/stat housing
Old Aug 28, 2008 | 07:03 PM
onefastek9's Avatar
Default Re: POS Wont Start (dtapia)
haha that always happens to many honda owners....
Old Aug 29, 2008 | 09:49 AM
bjfisher's Avatar
double checked and sanded down all the grounds and reset the ECU....i finally hear the fuel pump coming on now and ive got spark now. but at this point when i try to start it, it will crank, but it doesnt sound right, like not normal, kinda jerky almost like its out of time. but i didnt mess with anything other than the dizzy between pulling it from my brothers car and putting it in mine...so maybe something to do with ignition timing (which ive moved the dizzy everywhere and nothing), but cam timing shouldnt have changed at all...
Old Aug 29, 2008 | 01:02 PM
onefastek9's Avatar
CHECK YOUR SPARK PLUG WIRES, IF YOU MISSED WITH THAT, YOU MIGHT HAVE MOVED ONE TO THE WRONG POSITION.
Old Aug 29, 2008 | 01:37 PM
bjfisher's Avatar
wires are correct
Old Aug 29, 2008 | 07:09 PM
onefastek9's Avatar
had a guy bring a eg ls swaped in the other day and his car missed too, did a comp check and it cleared, did a injector check and it faild. have you check for resistence in the injectors?
Old Aug 30, 2008 | 05:01 PM
bjfisher's Avatar
no i havent...how do i do that?
Old Aug 30, 2008 | 07:41 PM
onefastek9's Avatar
Default Re: (bjfisher)
with an ohm meter what else, it's hella easy, all the info you need is in the repair book, if you don't have one, go buy one it will help you out alot
Old Sep 1, 2008 | 04:39 PM
bjfisher's Avatar
ok, so i got it started. however, the idle goes up and down between 1k-2k rpms.
i also figured out that the throttle body on it is off of an automatic and was told they are different. is this true? should i put a 5spd TB on? replace the IACV? both?
and what is the (i think its white) sensor on the back of the intake manifold closest to the driver side?
Old Sep 1, 2008 | 11:21 PM
civic95hbvtec's Avatar
White plug could be Air intake temp
Old Sep 2, 2008 | 08:14 PM
srmofo's Avatar
Default Re: (civic95hbvtec)
intake air temp sensor and the IAT sensor have the same plug, make sure they are not mixed
whytry2002
Oct 19, 2010 08:44 PM
zennx2k3
Sep 23, 2008 05:38 AM
DelsoldS
Sep 13, 2005 02:03 PM
vietjdmboi
Mar 8, 2005 06:33 PM
nitroacc0rd
Mar 1, 2003 11:08 AM
