boosting 12lbs sometimes. then 16lbs?
Old May 20, 2021 | 09:08 PM
V8SlayerH22's Avatar
Default boosting 12lbs sometimes. then 16lbs?
fully built 97 h22 prelude, sleeves, pistons, rods, crank, valves, springs, etc etc etc, precision 58,/58 turbo, 1000cc injectors, Neptune.
im running boost by gear, it should be 7-9 1st and 2nd then 15 3rd 4th and 5th. lately in 3 4 and 5 i am getting about 12-13lb boost however tonight i took it out and in 4th gear it jumped back up to 15-16lbs. what could cause this? i have a tial wastegate, I was gonna start by removing and cleaning it. any suggestions?
Old May 21, 2021 | 10:56 AM
Aradin's Avatar
Premium Member
Default Re: boosting 12lbs sometimes. then 16lbs?
Changes in air density/temperature mostly. It's getting warmer so less dense air = less boost. At night it cools down, so you're back to your target.
If you want it to be at your target in all weather, you need to tune the IAT compensation tables.
Old May 21, 2021 | 01:10 PM
i understand what you are saying but that is not the case here. there is not large enough difference in temp from day to night where i am. i think it may be something with the wastegate or a boost leak somewhere in the intercooler piping
Old May 21, 2021 | 01:40 PM
Aradin's Avatar
Premium Member
Have you looked at the logs to verify that?
Otherwise, we can't test your car for boost leaks or wastegate issues over internet forums so I don't know what you're expecting. Go rule that stuff out and report back if you're still having issues.
Old May 26, 2021 | 07:29 PM
update.
it was caused by one or the air lines from wastegate being melted crimped causeing less air flow. all good now!
edsperformance
Jun 15, 2010 02:36 AM
afrothunda713
Oct 9, 2004 09:27 AM
ringgold
May 11, 2004 09:38 PM
BLKCRX
Apr 29, 2002 11:16 AM
degradated
Oct 29, 2001 07:56 AM
