B20 turbo won’t idle with crome
Hey guys! First post so go easy on me with the tags and stuff 😂🙏
So here’s my setup. I’m running Crome on a p28 (Moates burn 2, chip) so I start with a p28 basemap, adjusted for injectors and engine size of course. It runs great, rich like 11.2-12 but not bad. Before boost, because you can’t add boost tables to p28 base. T3 turbo, 500cc injectors, gapped rings, gsr manual trans, stock maf, walboro 255, wide and afr & gague, home welded boost & exhaust piping
but whenever I put the p28 tables into the p30 setup it works, but as soon as I go into Advanced Boost Tools and add tables for boost, BOOM!!!!! NO IDLE! The car WILL NOT IDLE and I’ve been struggling with this for 12 hours straight, forums and everything.
again car runs fine right up until I add tables for boost. Then it needs gas to stay running. Will run down to 200rpm but dies when I let off the gas 10/10 times.
whaddya think?
whaddya think?
