96 Civic EK - Exhaust bolts unscrewing
Old Mar 25, 2021 | 04:14 AM
sushibar's Avatar
Default 96 Civic EK - Exhaust bolts unscrewing
Im doing some work on my car and had to uncrew the bolts between catalytic converter and th Exhaust pipe A
I put some penetrative oil over the course of few weeks before attempting to unscrew these nuts.
The nut came off with the stud, is this normal ? Did i just broke the whole assembly ?
Also as you can see in the pictures the engine bracket supporting the exhaust assembly seems cracked does this need replacement ?
Old Mar 25, 2021 | 06:54 AM
fonkernuckle's Avatar
Default Re: 96 Civic EK - Exhaust bolts unscrewing
Nut coming off with the stud happens often,IMO normal and will screw back in and can be torqued provided there is no split on flange where it tightens too (I have not encountered damage/split in about 8-10 cases that I have had.
Whether to replace the bracket-- if it was a ef or eg I would leave it till it causes an issue ince the exhaust is one piece to just about the cat. In a 96 I would replace it since the exhaust manifold is two piece right below that bracket since the split can contribute to the upper manifold piece tendaency to split. I have a 96 EX that suffered from such a maniford crack My 99 EX has not experienced this but it as you know is also a two piece although the location of the O2 sensor on the 96 vs 99 is different and might be a contributing factor. What would I do if this bracket was on my 99-- I would lieave it. In my 96 I would replace it..
Old Mar 25, 2021 | 06:59 AM
tony_2018's Avatar
Fish Twig
Looks like it snapped. Drill through it, retap it and put in new studs or use a nut/bolt combo.
Old Mar 25, 2021 | 09:14 AM
sushibar's Avatar
Thanks for the valuable input.
Does using a nut/bolt combo have any advantage ? Genuinely asking, does it make it easier to remove ?
Old Mar 25, 2021 | 09:16 AM
tony_2018's Avatar
Fish Twig
To me, I just do what I can to get it back on there. If the stud breaks off I'm going to get the rest of it out and look for a grade 8 nut/bolt combo. Move on.
Old Mar 25, 2021 | 11:18 AM
09chaplak's Avatar
Loves Tossing Salad
Even though Tony sucks on his sack most of the day, he does know what he's talking about.
Old Mar 25, 2021 | 03:13 PM
tony_2018's Avatar
Fish Twig
I mean who wants to deal with a chappy *** nut and stud all ****** day.
Old Mar 25, 2021 | 03:54 PM
09chaplak's Avatar
Loves Tossing Salad
Old Mar 25, 2021 | 08:06 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Now now children.....
The heat shield is hiding whether or not the stud snapped. If you can see through to the other side, you can reuse the existing stud. If you can't then it's just like Tony mentioned.
The bracket on the other hand, that is plainly broken and for me, I'd have to replace it, it would bug me otherwise.
trader8825
Mar 28, 2013 08:52 PM
brios86
Jan 2, 2009 11:47 AM
Wakes4Fun
Jul 28, 2008 01:23 PM
BigFiasco
14
Jul 24, 2008 11:31 AM
mdlagedcivic
Jan 6, 2003 05:57 PM
