B20 golden eagle sleeves
So what exactly are you asking? If you want help you have to provide some actual ******* information.
Are you asking how much the block will be able to to take after being sleeved? because in that case maybe you should ask Golden Eagle.
Or, are you asking how much power you will make? In which case you provided no information other than its a stock B16 head and has some kind of turbo on it. So since youre going to be vague, Ill give you the vague answer that youll make somewhere between zero and 500 hp. Most likely zero though, since it'll be be blown up soon enough.
If you have enough injector, youll be able to max out the turbo. Idk what "T3" you have, but if its an old dinosaur Im surprised you havent already maxed it out at 300hp.
Figure out what turbo you have, find a compressor map, and thats your answer.
It’s a rev9power v-band turbo .65 trim
Youll allways be better with a 200$ USED/CHECKED genuine holset HX35 from ebay tho... Cheapest copy turbo id ever use if any are the turbos from pulsar.
stockmr2
Mar 9, 2006 12:51 PM
