B20 golden eagle sleeves
Old Mar 18, 2021 | 10:31 AM
Zurox99's Avatar
Default B20 golden eagle sleeves
How much HP and boost can a b20 block handle with golden eagle sleeves and stock b20 head
Old Mar 18, 2021 | 11:27 AM
Full_Tilt's Avatar
Default Re: B20 golden eagle sleeves
All of it
Old Mar 18, 2021 | 09:21 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Why would you sleeve a B20 block ?
Old Mar 19, 2021 | 06:40 AM
Zurox99's Avatar
I already have a b20 turbo running 7lbs I’m sleeving the block and getting a b16 head to go b20v but as of rn it’s stock head and wanted to know what power ima be running after
Old Mar 19, 2021 | 07:03 AM
Full_Tilt's Avatar
So what exactly are you asking? If you want help you have to provide some actual ******* information.
Are you asking how much the block will be able to to take after being sleeved? because in that case maybe you should ask Golden Eagle.
Or, are you asking how much power you will make? In which case you provided no information other than its a stock B16 head and has some kind of turbo on it. So since youre going to be vague, Ill give you the vague answer that youll make somewhere between zero and 500 hp. Most likely zero though, since it'll be be blown up soon enough.
Old Mar 19, 2021 | 07:21 AM
Zurox99's Avatar
it’s a b20b with a t3 .65 turbo and a 55mm bov, with stock b16a head, with just 7lbs of boost I make 295hp and 210lbs of torque I’m sending my block to golden eagle And I’m asking how much boost can I run with this setup, I plan to eventually build the head and get a gsr tranny (rn I have a b16 tranny)
Old Mar 19, 2021 | 07:53 AM
Full_Tilt's Avatar
If you have enough injector, youll be able to max out the turbo. Idk what "T3" you have, but if its an old dinosaur Im surprised you havent already maxed it out at 300hp.
Figure out what turbo you have, find a compressor map, and thats your answer.
Old Mar 19, 2021 | 08:00 AM
Zurox99's Avatar
It’s a rev9power v-band turbo .65 trim
Old Mar 22, 2021 | 03:24 AM
Balor_Gr's Avatar
Its easy 600hp block if its done by golden eagle. Youll need a b16/b18c head if you want your life to be easier and a forged piston/rod/valve spring -retainer set for anything over 300 hp.
Youll allways be better with a 200$ USED/CHECKED genuine holset HX35 from ebay tho... Cheapest copy turbo id ever use if any are the turbos from pulsar.
Del Sol
Mar 3, 2013 12:39 PM
Jhobs3
Feb 4, 2013 10:45 AM
AK94GSR
Nov 9, 2007 09:53 AM
stockmr2
Mar 9, 2006 12:51 PM
PTR1
May 4, 2004 07:07 PM
