Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
K swapped em2 issues!
Old Mar 2, 2021 | 04:08 AM
Mathew Lepp's Avatar
Default K swapped em2 issues!
Hey guys just need some help here diagnosing some issues I have with my k20z1 swapped em2, currently stock motor, stock ecu, action stage 2 clutch. And just a bunch of bolt ons in the suspension department. Currently having issues with a misfire code that I can’t seem to shake, haven’t had the chance to run a compression test but I wanted to have an idea of what some of the issues could be. Misfire on cycling we 1 and I have bad 02 sensors, which could be causing the issue as the car is running rich and could just be fowling plugs regardless, I just don’t know what would cause this other then bad plugs? Could bent valves cause this issue? The car runs and drives good with no noticeable misfire. Very smooth running engine and makes very little valve train noise. Just looking for a list of what to go thru before I pull the engine out of the car.
98jdmcivic
May 26, 2008 09:01 AM
veilsides2000
Jun 3, 2007 05:29 PM
veilsides2000
Honda S2000
22
Jun 1, 2007 11:12 AM
boostjunkie757
Sep 3, 2004 01:19 PM
