Honda S2000 Honda S2000
misshift.
Old May 30, 2007 | 04:54 PM
veilsides2000's Avatar
Default misshift.
Okay.... first of all it wasnt me driving. Rather my retarded friend. He basically pulled the infamous "3rd to 2nd" misshift in my s2000. and 3rd was at redline. 2002 s2000
I immediately had him pull over and now my car idles bad, and the engine seems to have gotten louder. The car drives fine after 3k rpms but it does hesitate below that. HEres where my confusion lies.....
Given past experiences, i know that my valves might be out of whack. Its at the honda dealership right now, the mechanic looking at the my car ran the codes and said that the only code it was throwing was a missfire code. The car had a recall for spark plugs that i never knew about. He looked at my plugs and said that they look pretty bad. They are putting them in and i should know more in depth tommorow.
Question1: If the misshift was really severe, then at least one of my spark plugs should be broken correct?
Question2: Ive heard many stories about misshifting s2000's and usually nothing bad happens, is this true?
Question3: What else should i look for.? i already asked him to do a leakdown and compression test.
Question4: if my valves are bent and such, how much am i looking to pay?
THanks a lot
Old May 30, 2007 | 04:56 PM
Default Re: misshift. (veilsides2000)
I know im stupid for letting my friend drive.
Old May 30, 2007 | 05:10 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
man at redline in 3rd and went to 2nd???? you lucking there isnt a hole in your piston.. chances are its your retainers...
Old May 30, 2007 | 05:34 PM
Default Re: misshift. (S@nt0s)
could bad spark plugs and that misfiring be a cause for the noise? and bad idle. Or should i not consider myself that lucky? lol
Old May 30, 2007 | 05:44 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yes the spark plugs could be a factor but the fact that the motor was at 9K in 3rd and went to 2nd.. hopfully it was just a touch and your friend put the clutch in fast!!
Old May 30, 2007 | 05:47 PM
i think he did it at a pretty good rate. I wouldnt remember. Too well lol. I was drunk. hence my friend driving.
I just hope everything works out lol. I dont want to spend too much. HOw much would it cost if i te valves were fucked?
Old May 30, 2007 | 06:16 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
i bit of $.... they will have to do a leak down/comp test.. if the valves are all good then it will be cheaper with just the retainers and a valve adjustment. but if the valves are bent thenthe head needs to be removed... so with that comes
headgasket
head resurface
replacement of valves
retainers if need be
valve job
removal/install of head
valve adjustment
etc
Old May 30, 2007 | 06:18 PM
do you think my valves are messed up by my description above?
Old May 30, 2007 | 06:41 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
it can be but i cant say unless i was there with the motor in front of me...
Old May 31, 2007 | 04:30 AM
kool kool thanks
Old May 31, 2007 | 09:35 AM
anybody with any advice?
Old May 31, 2007 | 10:46 AM
SilverDc2's Avatar
you just have to wait it out, some get lucky and some blow motors. and the rest in between..
Old May 31, 2007 | 10:57 AM
Default Re: misshift. (SilverDc2)
okay well the tech at honda said that cylinder #1 has no compression at all. geez these guys charge up the ***. $500 just to take the head of lol. im looking at least 2000 dollars here
Old May 31, 2007 | 04:24 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veilsides2000 &raquo;</TD></TR><TR><TD CLASS="quote">okay well the tech at honda said that cylinder #1 has no compression at all. geez these guys charge up the ***. $500 just to take the head of lol. im looking at least 2000 dollars here</TD></TR></TABLE>
Correction, your FRIEND is looking at at least 2000 dollars here.
Old May 31, 2007 | 04:43 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
sounds like bent valves then......
Old May 31, 2007 | 05:32 PM
Donkey85's Avatar
yeah i would be asking my buddy for a little cash since he was the one that blew the motor
Old Jun 1, 2007 | 04:30 AM
Default Re: misshift. (Donkey85)
yeah he is offereing to put up cash. But cant do anything right now, so its coming out of my pocket for now.
I looked at the head and specifically the two intake valves on cylinder #1 are stuck.
The retainers and springs look fine.
Old Jun 1, 2007 | 06:07 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
glad i can call it without even looking at it!
Old Jun 1, 2007 | 07:12 AM
SilverDc2's Avatar
i would replace the retainers just for safety
Old Jun 1, 2007 | 09:23 AM
yeah, i checked the retainers for any cracks in them.... but didnt see anything.
THe mechanic said that he can jsut replace those 2 valves and were good to go. MY question is.... shouldnt i replace all of the valves or will i be good with just those 2?
Old Jun 1, 2007 | 09:29 AM
b20integrapower's Avatar
I would replace the retainers. I know you have looked at them, but microscopic or hairline factures may still exist. It seems extreme going into this much depth into looking, but id take a magnifying glass to it. Those tiny cracks over time will grow, its just a simple law of nature.
Old Jun 1, 2007 | 10:13 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: misshift. (b20integrapower)
fuuck a mag glass NDI that bitch.. i would replace all of them jsut for safe keeping...
Old Jun 1, 2007 | 11:12 AM
Yeah hopefully honda doesnt charge me an arm and a leg for the valvetrain lol
BanzaiBeast
Apr 20, 2012 03:23 PM
HondaKyle
Honda S2000
Jun 14, 2007 10:35 PM
veilsides2000
Jun 3, 2007 05:29 PM
b18c195
Honda S2000
11
Jan 9, 2006 01:19 AM
ActiveAero
Jan 16, 2002 06:12 PM
