PM6 ECU Code Help
Old Feb 22, 2021 | 04:21 PM
The Real McCoy's Avatar
Default PM6 ECU Code Help
So I have done alot of reading back and forth between this form and many others.
I have a PM6 ECU and it is flashing 20 times. I have read it doesn't go to 20 or that 20 is 2 long lights. So I am sorta confused. Is it a 20 or is it just a 1? Its basically on off on off on off ect... 20 times. Then it takes like a 2-3 sec pause and repeats. Can any one help me with this issue.
Is it a ELD issue?
This is in a 88 hatch with a D16A6.
Old Feb 22, 2021 | 05:55 PM
jlicrx's Avatar
Default Re: PM6 ECU Code Help
it does go to twenty and twenty is electric load detector
Old Feb 22, 2021 | 05:59 PM
Is this something I need to replace or what. And where is it located. I tried looking for a part but I cant find a part.
Old Feb 23, 2021 | 05:53 AM
kraquepype's Avatar
10 Year Member
The electric load detector (ELD) is a circuit in your engine fuse panel that can tell when there is an electrical load and adjusts the idle and alternator output. You can search online for "ef civic eld" and get some useful info.
If the car is driving fine without it you should be OK, but you may notice headlights dimming under load, for instance if the fans, defroster, or other accessories are on. Mine has been disabled for a while through Hondata and I haven't noticed any issues aside from what I mentioned.
Old Feb 23, 2021 | 06:24 AM
jlicrx's Avatar
usually the cause for the code 20 is an underperforming alternator - diodes bad
Old Feb 23, 2021 | 04:27 PM
Thanks for all the input. I went through and check and upgraded some grounds cleared the ecu codes as well and it went away and hasn't come back.
K24EK
Mar 4, 2008 08:54 AM
kewbee7
Jul 18, 2006 10:15 PM
hitvtecgetloud09
Nov 10, 2004 07:02 PM
Jockobo
Jun 29, 2002 12:38 AM
vsual
11
Feb 13, 2002 03:48 AM
