HELP (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP
Electrical Load Detector (ELD) off a 99-00 civic hb.
where is this or how can i fix it. i think its makin my lights flicker and dim. i read that it may also make my speedo go all crazy which itpretty much does.
where is this amd how can i fix this problem, got emissions next week.
New User
Re: HELP (ELD) ELECTRICAL LOAD DETECTOR?? Code 20, wtf is that? HELP (kewbee7)
An E.L.D. detects the load on your altenator, and this load is translated to your ECU which helps the ECU determine the right amount of output power to have the car run at idle. Usually when you have this code your altenator is going bad is not providing constant power, from what I understand its located in the fusebox on most Hondas.
Good luck with it.
Good luck with it.
Re: HELP (Slick_99)
Some hondas actually have the ELD inside the ECU or inside the alternator itself. It all depends on year and model. Once you figure that out, find an ecu diagram for your car and check to see if its in there. If not then youre gonna have to replace the alternator or the piece in your fuse box.
I posted about this a while ago, and found out my ELD was in 1 of 2 places: ECU or Alternator.
Hope that helps some
The ELD is under the underhood fusebox.
http://canadiangeek.net/car/pics/100_0428small.jpg
Have you had the charging system thoroughly checked out? BTW crossposting in multiple forums is sometimes frowned upon.
Re: HELP (Slick_99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slick_99 »</TD></TR><TR><TD CLASS="quote">An E.L.D. detects the load on your altenator, and this load is translated to your ECU which helps the ECU determine the right amount of output power to have the car run at idle. Usually when you have this code your altenator is going bad is not providing constant power, from what I understand its located in the fusebox on most Hondas.
Good luck with it.</TD></TR></TABLE>
Homeboy is right on. And its in the fusebox. Check the Alternator wiring for resistance. (I had a break in the white 10ga power wire, it was grounding out on the passenger side shock tower) Check the alternator itself too.
ok.. so i swapped out my fuse box and put in a good wrking one, and got rid of my code 1? weird.. but still throwing the code 20... speed gauge still not wrkin right. after i changed in a wrking speedo and gauge cluster.. still nothing.
still got codes: 41, 65, and 20.. plan on changing the o2 sensors tomorrow..
im gonna try puttin in a new alternator, and mayb new ecu..
usdm_ED7
06-26-2012 01:47 PM
