Distributor question
Old Feb 20, 2021 | 03:11 PM
Jeremy64's Avatar
Default Distributor question
96 accord ex 2.2, obd2
So i changed the cap rotor and ignitor. The cap and rotor where getting worn out and the ignitor from hitachi was 23$ from rock auto so why not.
I marked the plug wires from the left as in the book cylinder 1 on the right. Then i was marking the old cap as numbered in the book and my wires are off by 1. But the car ran just fine and did not have codes.
So i tried it the book way and the car would not fire. So i put the wires back the way they came off. Started like it was mis fire than ran smooth after 5 seconds, seems normal as before
is the ecm making it work but adjusted so it will run. If that is the case should i put it as the book says and try to start it again on hopes that the ecm fixes itself.
Also note that i did not rotate the crank to tdc before removal of the distributor but i did mark it
Old Feb 20, 2021 | 03:31 PM
99stockcivic's Avatar
Default Re: Distributor question
Can you take some pics to show us what you did? Doesn't make sense to me. How can you be off by 1? DO you mean you plugged the 1 into the 2, the 2 into the 3, the 3 into the 4, and it works fine that way? Maybe you had reversed something, as the cap isn't 1-2-3-4, if I remember correctly.
I know this is not the same year, but I am using as example of what I suspect happened.
Old Feb 20, 2021 | 08:33 PM
Jeremy64's Avatar
Fallow number 3 wire marked on distributor
Old Feb 20, 2021 | 08:35 PM
Jeremy64's Avatar
this os my book. Bu the way did the new power steering pump fix you issue
Old Feb 20, 2021 | 08:41 PM
I see, that is weird, i'm not sure what to think of that.
And yes, power steering pump fixed my issue 100%. Must have just been an old tired pump.
Old Feb 20, 2021 | 08:45 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your EX is a F22B1 engine. See Honda service manual difference for F22B1 vs. F22B2.
Old Feb 20, 2021 | 08:46 PM
Jeremy64's Avatar
it had me stumped still does with the firing order. Made me think about 67 times how it should be it ran ruff but smoothed out like normal. the book way would not fire at all. I am still confused imo. Thank you thiu and glad to hear it was just the pump
Old Feb 20, 2021 | 08:53 PM
Jeremy64's Avatar
That is not in my 96 -00 repair manual at all but that is how it was and how it runs. Just the wrong info thank you for the help i knew they have two different distributors but did not have a clue that the order was different.
KingReset
Nov 5, 2014 02:44 PM
SethAZ
Nov 16, 2013 02:32 PM
edavila1
Jan 31, 2009 09:56 AM
monalisa overdrive
Apr 19, 2004 09:07 PM
FastNFurious
Jun 19, 2003 09:14 PM
