Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
New Product Release-MaXpeedinRods New ECUs
Old Jan 18, 2021 | 11:12 PM
MaXpeedingRods's Avatar
Icon3 New Product Release-MaXpeedinRods New ECUs
Developed by MaXpeedingRods engine control unit tuning technical team, MaXpeedingRods ECU runs with our own software that we modified to optimizes the electronic signals to and from the engine, which can improve the parameters set by the manufacturer.
It has been tested by Dynapack and Mainline horsepower machines, which can unlock most of your car's potential performance.
Seven Significant Functions Of MaXpeedingRods ECU
1. Up to 30% HP and Torque
2. Up to 10% fuel saving
3. Improve engine energy efficiency ratio
4. Reduce engine coke deposits and exhaust emission
5. Slow down shift frustration
6. Better power connection
7. Slove the problems of original models( the low idling speed leads to easy to stall, etc.)
Six Advantages Of MaXpeedingRods ECU
1. Aluminum shell: CNC aluminum high-temperature resistance, corrosion resistance, flame retardant, fast heat dissipation.
2. Three-proof design: waterproof, dustproof and shockproof.
3. Competition-grade wiring harness: customized wiring harness, power output lasting.
4. Non-destructive installation: original installation, does not affect the original car warranty and quality inspection.
5. Wide coverage: applicable to more than 90% of Turbo models in Germany, the United States, Japan, South Korea and China produced.
6. Easy installation: plug and play, compact and portable, simple operation.
Many models are covered this, for more details, please check the link: MaXpeedingRods ECU
Anyone wonders about the easiest install steps, just stay tuned[img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Old Jan 20, 2021 | 12:19 AM
Default Re: New Product Release-MaXpeedinRods New ECUs
Test report of MaXpeedingRods ECU published!!! https://blog.maxpeedingrods.com/?p=4168
Guess what does the ECUs for Honda look like
jimmy63
Honda Civic (2006 - 2015)
May 10, 2020 05:01 AM
Soliate
Mar 31, 2019 05:07 PM
jtindel
Engine Management and Tuning
Jul 25, 2012 10:23 PM
Civic168
Jul 5, 2006 06:04 PM
xxxmikenicexxx
May 19, 2006 08:36 PM
