Speedometer problem
Old Aug 21, 2020 | 05:30 AM
mhmdtrby's Avatar
Default Speedometer problem
Hello everyone
I have 1991 Accord bought it used and it was in terrible condition, the speedometer is not working, nor the odometer. Now I'm a bit confused because the car changes gears normally, everything seems fine so I assume it's not a faulty speed sensor but as I knew as long as the sensor is fine the odometer should be working even if the speedo's not. Any thoughts? Thanks
Old Aug 21, 2020 | 05:42 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Speedometer problem
Usually if the VSS was faulty, there may be a trouble code. Even with a faulty VSS, the transmission will still shift as usual.
See this link for testing of VSS, wiring, and at the speedo.: VSS - Vehicle Speed Sensor Troubleshoot, Repair, Replace - How To.
ezwind72
Sep 9, 2010 10:22 AM
ek4h
Apr 15, 2007 07:49 PM
Canonm7
Aug 28, 2003 03:05 PM
hitekper4mance
Jan 7, 2003 04:40 PM
Mike95lude
Feb 18, 2002 09:50 PM
