Capacitor leakage
Old Aug 11, 2020 | 03:59 AM
Jvke's Avatar
Default Capacitor leakage
Recently bought this virgin P28, bought a chip kit from phearable and installed it. Car sounded perfect, idle and AFR was good but when I took it for a test drive the car began to bog and it felt like I was getting a fuel cut. Eventually the car would die and struggle to turn on so I start to diagnose to find out whats causing the car to shut off and bog, so far I can’t find anything that would cause these symptoms. I opened up my ecu and this is how it looks, I don’t know how or what caused this to happen cause when I bought it and inspected it I didn’t notice any of this and its pretty obvious. My question is how bad is it and can it be fixed or do I have to buy another ecu ?
Old Aug 11, 2020 | 04:20 PM
Swift's Avatar
Default Re: Capacitor leakage
That looks like it could be leakage. But any capacitor gets weaker over time.
Old Aug 11, 2020 | 05:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Most likely fixable with replacement of capacitor(s) and any other board component as needed, and resoldering certain spots.
Old Aug 12, 2020 | 04:08 AM
Jvke's Avatar
I will double check to make sure that’s the only one that’s leaking when I get home...does a leaking capacitor really have that big of an effect on how the car runs ? I will make sure to drop more pics if I find more damage
Old Aug 12, 2020 | 06:06 AM
Swift's Avatar
If you are there replacing one, I suggest replacing them all since you are there.
I have never had one bad enough to keep one from starting, but I have replaced all before when they all looked good and the car was noticeably smoother at all points.
Just a side note many manufacturers in the 80s and 90s used the brown caps, cant recall manufacturer that were later found to be suspect. Caps are filled with a goo that can dry out or leak over time, they just degrade.
Someone with more knowledge probably has better memory than I, but I believe the caps on these boards are rated for something like 100,000 hours.
Old Aug 12, 2020 | 06:34 AM
Jvke's Avatar
Yea im gonna go ahead and replace all the capacitors I just hope that the board didn’t get damaged. How do I know if the board is no good, what should I look for?
Old Aug 12, 2020 | 06:48 AM
muellersfan's Avatar
Unless you see obvious damage to some board circuit traces, move forward with the assumption that replacement of electrolytic capacitors will solve the problem.
Old Aug 12, 2020 | 07:04 AM
Jvke's Avatar
what would you recommend using when cleaning it ? Last time I used regular brake cleaner and a toothbrush lol
Old Aug 12, 2020 | 10:06 AM
Brake cleaner is too strong of a solvent for PCBs. 90% isopropyl alcohol and a Q-tip or toothbrush should do the trick.
WideBodyFEELZ
Engine Management and Tuning
Sep 24, 2020 07:45 AM
crxb16a90
Mar 4, 2011 02:06 PM
kentuckyhatch
Jun 30, 2009 10:05 AM
Civicman86
Nov 11, 2006 09:05 AM
MIKES
Jul 25, 2002 08:49 AM
