Afr at High Cam engagement.
Old Aug 8, 2020 | 01:57 PM
LadyKiller1998's Avatar
Default Afr at High Cam engagement.
Hello guys little background on the car 1998 Acura El with b16a2 running;
t3/t4 turbo, walbro 255, tial 38mm Wastegate with 7psi spring combination running stock head/block except for arp head studs. Tuning with crome dealer on a p72 obd1 ecu, running AEM wideband, prosport boost guage paired with prosport electric oil pressure guage.
Now to the question where should my AFR be at Vtec Engagement here's a recent datalog of the high cam. Thanks in advance !
I understand where my AFR should be while in boost but what about the vaccum of high cam map.
Old Aug 8, 2020 | 03:21 PM
Txdragon's Avatar
Default Re: Afr at High Cam engagement.
You're running lean. 11-11.8 should be your target.
Old Aug 8, 2020 | 03:35 PM
Thanks for the reply! So as soon as I get onto the high cam map I should be in the 11.8's? I will change my target afr's and go from there!
Old Aug 8, 2020 | 03:55 PM
Txdragon's Avatar
Roughly. Your VTEC kicks in about 53-5400? Depending on your boost pressure. What are you pushing? If I'm reading you pic correctly up there, not very much. So by 'TEC kick, 11.8 is a start, working to about 11.5-11.0 up top.
Old Aug 8, 2020 | 04:23 PM
Getting better than!
​​​​​I'm only pushing 7PSI no idea how much HP sadly hasn't seen a dyno yet. Definitely feels better throughout the pull since I added some fuel.
Old Aug 8, 2020 | 04:35 PM
Txdragon's Avatar
Good deal! By full boost, you should be no leaner than 11.8. You can fatten it up a bit more to about 11.5-11.2 but I wouldn't really go too much more than that.
Old Aug 8, 2020 | 04:50 PM
Thanks for your help!! Me and the car appreciate greatly 😁 One other thing, if the datalog doesn't log certain values it's just because I'm so far off?
Old Aug 8, 2020 | 04:57 PM
Txdragon's Avatar
Glad to assist! Unfortunately, I'm not overly (or any) versed in crome so, i'm not sure about that..
Old Aug 8, 2020 | 05:00 PM
Understandable crome has been great to me but can't wait to upgrade. What would this mean on a different program?
Old Aug 8, 2020 | 05:04 PM
Txdragon's Avatar
For mine (Neptune), it's just not tracing those areas..
Old Aug 8, 2020 | 05:08 PM
Okay I'll keep working at it! I only ask because when I was overly lean it wouldn't trace those areas at all. Maybe I just answered my own question though haha happy boosting!!
widewhite
Aug 3, 2017 01:08 PM
intense4thgen
Jul 19, 2009 06:57 PM
tekturbo
Engine Management and Tuning
Jun 6, 2008 03:06 AM
booscivic
Jan 21, 2005 03:16 PM
yusoslo
Mar 28, 2004 09:14 AM
