800whp+ Turbo K24 - Fuel Options [Methanol/Race/E85]
Old Jul 19, 2020 | 08:18 AM
carloverx's Avatar
Default 800whp+ Turbo K24 - Fuel Options [Methanol/Race/E85]
All,
I'm slowly piecing together my K24 build and hit a snag trying to select which fuel to run. The car will be driven (not trailered) to the track (30 miles one way) and to local car events (say about 50 miles one way).
Please take a look and share your thoughts. Anything I'm missing? What are you experiences with driving a high HP street car off pump? Just kinda thinking out loud here:
Methanol Injection + 93 Pump:
Pros:
  • Inexpensive
  • Readily available (VP dealer a few miles from my me)
  • Can keep primary injectors small and friendly for street driving.
Cons:
  • Can I even make 900whp with this combo?
  • Additional complexity of the injection system / tune
  • Running out of Meth on the road leaves you SOL for high power pulls.
  • Inconsistent fuel quality from the pump
Pump E85
Pros
  • Cheapest option
  • Great power
Cons
  • Closest station to me with E85 is 30 miles/35 mins one way. I'd have to fill jugs and bring them back I guess. How quickly does this get old?
  • Fast consumption
  • Requires 2000cc+ injectors that will only work well with E85 (meaning, I can't ever run straight pump without it running rough)
Race Fuel
Pros
  • Great power
  • Consistent fuel quality
Cons
  • Brutally expensive
Any experience with being inconvenienced by not having local E85? Also, just writing this out makes me want to research a dual-injector intake to run 93 and e85.
Bonus question:
Considering 6766 or s369sxe for the turbo setup. Anything else worth considering for the 850whp range with some overhead?
Thanks!
Old Jul 22, 2020 | 04:35 AM
extremeracer's Avatar
Default Re: 800whp+ Turbo K24 - Fuel Options [Methanol/Race/E85]
>> Pump E85 with a Flex Fuel sensor and run Ignite Red or something similar for race days. You can operate in a range of E70 (assumed) to E98 then and make use of commercially available filling stations. If your flex fuel is setup correctly the tuner will be able to scale your tune and boost from ~E30 to E98.
93+Meth won't get you into the Hp target range safely - and you'd need to be running a direct-port system to flow the quantity required.
Old Jul 22, 2020 | 08:22 AM
AZ_CIVIC's Avatar
So 850WHP and driving 50 miles one way and back, what happens if you break? I would just order a drum of e85, when you run out take the drum and fill it up. Also 2000cc injectors run fine on pump gas but the only time I would run pump gas is if the car was going to sit then I would drain the e85 and run pump 91 through the injectors to keep them clean.
Old Jul 24, 2020 | 03:16 PM
carloverx's Avatar
Thanks for the feedback. I thought about this a lot all week. In the end, race gas is too expensive and methanol is too weak, so I'm stuck with E85. Wish me luck, haha.
BoostModeCivic
Jul 22, 2015 10:57 PM
soloDC
Mar 31, 2015 09:38 AM
4cylfiend
Aug 29, 2012 07:56 PM
tuhboek
Sep 16, 2010 09:24 AM
B16Civic93
Mar 6, 2005 11:18 PM
