BOSCH O44 inline fuel pump
Havnt gone to get my tune yet but i'm running a Bocsh 044 fuel pump with the walbro 255 intank/ID 1000cc injectors/weldon FPR/ built motor&head/BEP S366.
Wondering what kind of power ppl are making and ET ppl are running with the 044 inline pump. Or anybody with similar set-up please chime in.
Thanks
Thanks
Thanks
Thanks
I would have thought the injectors would be the weak link in that list of parts to high hp, the 044 on its own would be enough for 550hp plus
My goal is a 750hp car consistantly running low 10's with the potential to dip into the 9's.
What do you think??
Turbo will make that power.
Fuel supply should be fine, given no issues with voltage under load and supply line size is sufficient based on the fuel you are going to run.
Only thing on the edge with that combination would be the ID1000's for the power goal you are wanting, with upping the fuel pressure you will flow more from the injector yet sacrifice on flow from the fuel pumps; and with the walbro 255 in the mix you don't want to go much past 80 to 85 psi of total fuel pressure as you will blow the bypass on the pump.
It also depends on what gas you are going to be using. With that exact same fuel setup. I made 700hp on e85 with that same turbo.
I'm sure with race gas it will be a little more.
Good luck! Keep us posted.
With the 255 / 044 combo. and ID1000s, you could run 50 psi base fuel pressure + 20 psi boost and not run out of "pump". Somewhere between 75 and 85 psi (base + boost total), the ID1000s would outflow the pump(s).
I have a similar fuel setup albiet not a B series, I am a sohc F22b1 motor with some winds on it from a billet 62mm. 255/ 044 inline/ weldon regulator/ ID1000's/ etc. 613whp / 514 wtrq with room left in it, Tony1 tuned... 112 gas for fuel.
Edit: 60psi base pressure btw.
If the 255 is just feeding the 044, he can crank the pressure up as high as he wants; the differential pressure between the two pumps stays around 10 psi (10 psi being the "load" on the 255). There was a thread about 044s making noise a while back, long story short- I ran a test on my friends car and posted the vid. in that thread. From 50 psi base to 90 psi base (rail) pressure, the differential pressure stayed right around 10 psi.
https://honda-tech.com/forums/showth...2773737&page=2
I feel I should note - that is NOT me in the pic posted with the video! that's swappedturboegg
post #31: video (quality sucks, more for proof of the test than anything else)
post #36: explanation
And in that case you just doubled the flow of a single 255. No increase in psi capability, just double the flow.
Thanks!
Can you please clarify the above statement that running a setup of two walbro in series is not practical.
I thought that I saw a post where someone posted a graph with a setup running 2 walbro's in series making approximately 800 whp on a B series turbo setup.
