OBD1 conversion problems. Can't pull codes WTF
Old Nov 15, 2002 | 05:55 PM
Nameless RB26's Avatar
Default OBD1 conversion problems. Can't pull codes WTF
I plugged in Kenji's chipped P28, and his conversion harness today.
00 JDM ITR, 2000 Si harness, 99 Civic hatch
I knew it was going to throw a code or two because of the vtec pressure switch, but the problem is we can't even pull codes from it. We hooked up the scanner, waited 15 seconds, and we got nothing. It won't read it. The CEL is on!
The idle fluctuates for about 15 seconds (up, down, up, down, up, down) then it will calm to about 1300. It does this everytime I let it go to an idle.
My questions are:
-Would not having a vtec pressure switch be causing all this?
-Is there an OBD1 component that I need to include somewhere when converting OBD2 - OBD1?
I wasn't getting any CEL's before when I was running the CTR ecu.
HELP! thanks
Old Jun 11, 2003 | 04:15 PM
Neukin's Avatar
Default Re: OBD1 conversion problems. Can't pull codes WTF (Nameless EJ6)
didi you ever figure out what was wrong...
Old Jun 11, 2003 | 06:12 PM
91DA9's Avatar
Default Re: OBD1 conversion problems. Can't pull codes WTF (toyosupr)
You have to hook a wire up to ECU pin D4 (If you have a complete harness it is a BRN wire and jumper it to the GRN/WHT wire on D22
Old Jun 11, 2003 | 07:37 PM
Default Re: OBD1 conversion problems. Can't pull codes WTF (91DA9)
Nope, scanners just don't work with OBD conversion ****.
But the idle thing.. yea I fixed that. Had to plug up the cruise control vacuum on the back of the intake manifold.
The check engine light was my vtec pressure switch.. and I now have one.
Man I feel weird reading my old stuff..
TurboBumblBee
Sep 22, 2005 06:47 AM
IDriveHonda
Feb 23, 2005 07:09 PM
B18 CYA
Jun 1, 2004 11:22 AM
Nameless RB26
Nov 16, 2002 01:26 PM
