Problems converting to OBD1
I plugged in Kenji's chipped P28, and his conversion harness today.
00 JDM ITR, 2000 Si harness
I knew it was going to throw a code or two because of the vtec pressure switch, but the problem is we can't even pull codes from it. The CEL is on!
The idle fluctuates for about 15 seconds (up, down, up, down, up, down) then it will calm to about 1300. It does this everytime I let it go to an idle.
My questions are:
-Would not having a vtec pressure switch be causing all this?
-Is there an OBD1 component that I need to include somewhere when converting OBD2 - OBD1?
I wasn't getting any CEL's before when I was running the CTR ecu.
HELP! thanks
My questions are:
HELP! thanks
http://hondata.com/techecuid.html has some information there
Yes, I have a conversion harness. (of course!)
Anyways, I fixed the idle problem. I put a piece of duct tape over this hole, for the time being:
I also checked the code, which is 22. I believe it has something to do with the vtec pressure switch, since I don't have that yet.
You need to also remeber that this is more of a racing ecu, Not designed for emissions or Perfect drivabilty! This ecu is designed to make power!
have fun! eric
have fun! eric
have fun! eric
have fun! eric
Kenji is the man!
