Does anyone know the name of the company that sells test pipes that don't cause a CEL?
Old Nov 15, 2002 | 04:29 PM
jdmspoonitr's Avatar
Default Does anyone know the name of the company that sells test pipes that don't cause a CEL?
I would like to run test pipe at the track without having to buy a new ecu. My friend told me that one of his other friends had a test pipe with cat material on the outside so that it would "fool" the o2 sensor into thinking everything is normal. This would allow for no CEL without changing ecu's. Does anyone know the name of the company that makes this test-pipe and does it work as advertised. thanks. if anyone else has any other suggestions that would be great.
When I asked AJ Racing, they told me that it all depends on the positioning of the o2 sensor bung. Can someone explain where I need to put the bung? If i can't find a ready made test pipe, I will just go to the muffler shop and have one made, but I need to know where to put the bung.
thanks for all of your help
sincerely,
Ken
Old Nov 15, 2002 | 04:32 PM
xjohnx's Avatar
Default Re: Does anyone know the name of the company that sells test pipes that don't cause a CEL? (jdmspoon
http://godspeed.hack.net
Old Nov 15, 2002 | 04:41 PM
thank you for the quick reply, have any of you guys used this test pipe? any gripes? are there other options as far as testpipes that are compliant with the OBD II?
Old Nov 15, 2002 | 08:39 PM
Dave-ROR's Avatar
well besides them being the wrong length and the cat material falling out a lot, oh and horrible customer service...
code 67 doesn't do a damned thing, if you wanta test pipe just remove the bulb, or wrap the O2 with tinfoil/wire tie it and replace every so often.
Old Nov 15, 2002 | 08:45 PM
ITR 00-1567's Avatar
New User
Test pipe compliant with OBDII... You're kidding... right?
Try www.testpipes.com they have test pipes available with cat material compressed in the o2 sensor bung. The CEL may still come on at random times. I have tried the Comptech hi-flow cat, and didn't have a CEL light for almost a year. Then it appeared one day, and never went away. I then bought an o2 simulator, had it wired in, and haven't had a CEL since.
Ian
Old Nov 16, 2002 | 07:02 AM
SW20 MR2's Avatar
Just get an o2 simulator to eliminate the CEL:
http://www.defcon-racing.com
Old Nov 16, 2002 | 08:32 AM
rainmanEK's Avatar
big strong guy
Or convert to obd1 and get a chiped ECU..!
eric
Old Nov 16, 2002 | 08:56 AM
sgT's Avatar
sgT
Thats like saying certain sex positions prevent pregnancy
Old Nov 16, 2002 | 09:04 AM
GiFF's Avatar
i've have godspeeds testpipe, had it for over a year and a half. no problems whatsoever. just a bit heavy though...
Old Nov 16, 2002 | 10:43 AM
baonest1's Avatar
lol
Old Nov 16, 2002 | 03:29 PM
typeR00-0005's Avatar
hey what's up kenny.finally got the car back and it pulls,missed hearing v-tech.what day are you guys going.
albert
Old Nov 16, 2002 | 03:37 PM
RacerXI's Avatar
I've had mine about 9 months with over 20K miles and no problems with it so far.
It's rather pricey for a test pipe, but it does the job.
BigBerz
Honda CR-V & Element
Aug 13, 2016 09:14 PM
mxracer420
Mar 25, 2010 04:33 PM
kool168
Jan 23, 2004 08:27 PM
Hybrid 350GT
Mar 6, 2003 09:44 PM
TURBOED-TEG
Jun 24, 2002 09:19 AM
