Oil pressure sensor to neptune rtp
Im trying to add a generic oil pressure transducer to neptune rtp. Im just not sure if im doing it correctly. I wired it up as per instructions on sensor and using d12 egr lift as signal input. On neptune i went to input settings and changed name of egr lift to oil pressure and added the voltages .5v for 0 psi, 2.5v for 50 psi, 4.5v for 100 psi. I see come up on datalog as oil pressure but it constantly reads 100psi. Am i doing this right? What is inputs2 tab for? Inputs2 tab under analog1 has no drop down to select the input source so that didnt make sense.
No that’s an input.
A pressure sensor has three wires. One signal, one reference voltage, and one signal ground. How have you wired up this sensor?
btw don’t use VCC1 for your reference voltage. That needs to stay dedicated to your map sensor. Everything else goes on VCC2.
No that’s an input.
