Question regarding D series head milling on the cylinder head
Old May 16, 2020 | 01:09 PM
purposebuilt's Avatar
Default Question regarding D series head milling on the cylinder head
Hi I was woundering if it would be ok to mill a y8 head .040. See I'm doing a d16a6/y8 mini me build and I'm gonna be using std lenght rods and vitara piston witch would yield a 7.84:1 but if I mill the head .040 it will bump it up to 8.5:1 witch is perfect. I know I can use the custom lenght p2p0 rods or speed factory but this is a budget build and wanna see how much power I can make for 1000$ so I will be useing d16a6 maxpeeding rods and vitara pistons, acl oil pump, A y8 head supertech valve springs, blox turbo cam, skunk 2 manifold since I have the block and head the rest will cost around 1000$
Old May 16, 2020 | 01:38 PM
Txdragon's Avatar
Default Re: Another d series build head milling ?
That's a whole millimeter off the surface. I don't recall directly offhand what the compression height is on vitara.
I think it's only half a mm different (?)
Old May 16, 2020 | 10:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Try it... and be sure to let us know when your engine jumps mechanical time because you will be unable to properly tension the belt.
Old May 19, 2020 | 10:48 AM
DaX's Avatar
DaX
Loved
Community Favorite
I've heard of folks decking a huge chunk off the block or head to make this work, but as stated you may have timing/tensioning issues, and you're going to essentially ruin a block or head for a set of cast pistons? Nah...either buy the long rods, or even better, buy some forged pistons and run regular length rods.
Old May 19, 2020 | 10:59 PM
Well I'm still gonna use the vitara but mill the head .030 and use.a y8 2 layer head gasket because I still wanna see how much power I can make with 1000$ and how much money it takes to run low 11s hi 10s. Now I just need to figure out timing . So any ideas
Old May 20, 2020 | 12:27 AM
Balor_Gr's Avatar
Brother i dont think the custom length rods are a big investment over maxspeeding rods.
Custom length rods are +1 compression ratio if i remember correct. You will be around 7.5:1 and custom length raise that to 8.5:1.
8.5:1 is acceptable. 7.5:1 will kill your mpg and power. At the end youll need a reliable adjustable timing gear and thats extra cost too.
Old May 20, 2020 | 03:42 AM
Txdragon's Avatar
Think I paid 150 or 160 USD for my TruTime gear.
Old May 20, 2020 | 05:20 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Question regarding D series head milling on the cylinder head
I think the VX (Z1) timing belt is 103 tooth, just a touch tighter than the Si (Z6) 104 tooth and 3 teeth tighter than the B7 belt which is 106 tooth. This is all 5th gen specs 92-95.
I don't know the teeth count on the 6th gen 1.6L motors.
Old May 25, 2020 | 03:44 AM
Thanx for all your input.
WHY7SPOOLIN
Jan 20, 2014 08:19 AM
4ghatch
Apr 13, 2008 11:26 PM
EJ8-y8
Mar 31, 2006 08:49 PM
hackish
Jul 28, 2003 01:04 PM
v4lu3s
May 22, 2003 09:08 AM
