Need Advice/Help With Broken Cylinder
Old May 9, 2020 | 05:26 PM
bluelights81's Avatar
Default Need Advice/Help With Broken Cylinder
Hello all. Looking for some direction. Recently took the fun car out and had a little too much fun. Ended up on a tow truck with what I thought was a blown head gasket. Just tonight I got everything torn down and saw this. Pretty depressing.
The motor is a boosted F23, with Wiseco K20 pistons and Molnar rods. Only has about 4K on the rebuild. Currently running about 18lbs at 290+/- HP. Wondering if this even repairable or if I should be looking at a new block. I think the head will be fine, I’m sure those small imperfections from metal particles can be smoothed out. Obviously my concern is the block. Also any insight on why this could have happened would be helpful as well.
Any help would be greatly appreciated. Thanks in advance.
Old May 9, 2020 | 08:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need Advice/Help With Broken Cylinder
That is terminal... you need a new block. It "May" be fixed if you install Darton Iron sleeves in it, but this depends on how deep the fracture goes toward the saddle of the block.
Old May 9, 2020 | 08:57 PM
Txdragon's Avatar
^^^ This. The head may still be salvageable, you now have a perfect excuse to polish your combustion chambers. Lol!
My question is: What the actual **** happened? I thought the F23 was a tough sumbitch?
Old Sep 3, 2020 | 09:07 AM
SixOne7CE1's Avatar
Stumbled across your build thread, sucks this happened, this is a great build!
I noticed you're in NH as well.I'm doing a similar setup and would love to pick your brain at some point in reference to where you had your tune done.
Anyway, I hope you're in the mend with this!
Old Sep 14, 2020 | 01:44 PM
tiemze's Avatar
Well looks like an open deck which = WEAK :D As you know b series open deck can only go to like 400-450. And that crack looks like classic detonation crack. Usually its cylinder 3 that detonates as it fires first. The scarring in the head is some debris that got compressed.
sgull
Jun 22, 2013 06:49 AM
h22god
May 4, 2013 12:14 PM
gizzmo222
Jun 24, 2011 11:37 AM
WABoostedb16
Jul 11, 2008 08:36 PM
crx1856
Sep 4, 2003 10:00 PM
