h23v head gasket selection advice
Old May 3, 2013 | 07:26 AM
h22god's Avatar
Default h23v head gasket selection advice
Hopefully some of y'all will be a good sport and help
Me figure out how thick of a HG I need...
One photo is of the block on its side (no oil pan yet) and
measurements from exhaust and intake sides of pistons
to deck I got those measurements -/+1 across the board.
And I'm trying to figure out if I measured the head recess
from the correct position. The head and block seem to have
both been milled/decked before and I just had them skim both
Again to make sure they are straight and true.
I can measure again if I didn't do it correct if someone
will please explain the proper way on the head or block.
Really need to know how thick I should buy a cometic
HG I was thinking a .060 but now I'm not sure... they sale
Them as thick as I could ever need but I'm also trying to
Pull a 12 1/2 1 compression ratio and not really sure how to
Go about it with HG thickness...
Help a feller out please...
Old May 3, 2013 | 10:03 AM
h22god's Avatar
Default Re: h23v head gasket selection advice
Trying to drink the formula for this into my head...(can tilt guzzle guzzle)
So the pistons are out of the block 0.045+/- 1(in) on all 4. So that's a piston
To deck height of +0.045 ... correct? So the factory HG is 0.026 (in) crushed ...
Correct? So that's a 0.071(in) to be at a OEM spec block and crushed HG setup
Right? But then comes the fact the head is milled before I was the owner and
Then I skimmed it to just be right on. So I'm not sure if I add HG thickness
for the head being milled or is that just where having the camshafts degree'd into
Come to play. And I am having it done anyway it goes about the HG.
Old May 3, 2013 | 10:23 AM
ESP.net's Avatar
What ever your piston sticking out of hole is add atleast another 30k to it.... that will be your headgasket thickness
+45K is a bit out of the hole... what pistons,crank,rods you using?
Old May 3, 2013 | 01:40 PM
h22god's Avatar
Type s pistons, f22 h beam rods 142mm I think,95 mm crank
Yea it is a bit far out, I think that's because someone took. 0.010
Off the block before and I did to when I had it resurfaced.
Old May 3, 2013 | 01:44 PM
h22god's Avatar
But thank-you for the quick answer back. And does the head being
Milled need me to add more thickness?
Old May 4, 2013 | 08:39 AM
ESP.net's Avatar
So decked roughly 20-25k... thats a bit... yes if head has been resurfaced that needs to be figured out how much... Sounds like your going to be in the 80k area thick...
Old May 4, 2013 | 10:50 AM
h22god's Avatar
Yea that's what I'm thinking. A 75 or 80... thanks again.
Sense I used OEM oversized pistons I'm stuck between
The 88 and 87mm bore head gasket too. I talked to a
Rep for cometic on here and he said the 87mm fits
Upto a 87.5mm bore and me being at 87.1/4 It should
work. Have you ever heard about this? I just don't want
to buy the wrong one... I would clay the motor right now
But there's no way my old OEM head gasket will work so
I'm stuck measuring and hoping it turns out right.
Old May 4, 2013 | 12:05 PM
ESP.net's Avatar
I would believe cometic they have never steered me wrong and always seem quite knowledgable with my questions.
Old May 4, 2013 | 12:14 PM
h22god's Avatar
awesome, new found confidence in what to order again. Thank you.
bruisedcivic
Jul 16, 2011 12:29 PM
strike1545
May 24, 2010 10:42 AM
bluesi00
Jan 31, 2005 10:54 AM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
C4wrx
Aug 4, 2002 06:23 PM
