What's needed to get tuned on e85
Old May 8, 2020 | 01:11 AM
purposebuilt's Avatar
Default What's needed to get tuned on e85
Hi I was woundering what I need to do to my car or parts replaced to get my car tuned on e85 and can I get it tuned useing chrome or do i need some like hondata. Thankyou
Old May 8, 2020 | 02:54 PM
TheShodan's Avatar
Moderator
Default Re: What's needed to get tuned on e85
Crome doesn't have the resolution to run E85. For best results you'll need to research the folllowing topics
*Flex fuel aensor
*Larger fuel lines that are Ethanol resistant-lined Stainless steel
*E85 compatible fuel pump
Larger EV14 styled high impedance injectors (1000cc+)
*Better tuning software
And of course, a better tuner
Old May 8, 2020 | 07:00 PM
NVturbo's Avatar
O.G. triple O.G.
I can't stress that enough. Don't deal with a lazy tuner that is only concerned about getting you in and out of the dyno like some drive thru window...just for the quick $$$. Cold start along with other features were never adjusted in mine
Old May 8, 2020 | 07:57 PM
*Flex fuel aensor
why would I need a flex fuel sensor I dont wanna run 2 different fuels and why do I need 1000cc+injectors I'm running a 12.5:1 compression ls vtec. I thought 600cc
Old May 9, 2020 | 04:49 AM
Txdragon's Avatar
You'll need a flex fuel sensor to monitor the ethanol content per tank as it *could* vary seasonally between about 50-85%.. Without this, you will have to test EVERY batch of gas you put in your tank to verify. The flex sensor just makes it easier to watch on the fly. 600cc injectors are NOT gonna cut it for any real power on ethanol, especially if you're looking to make 300+ to the wheels. Your 12.5:1 compression is nice but ain't gonna help the fact that ethanol will require up to 40% more fuel vs pump 93 and those 600cc will be maxed out well below 300whp. A buddy of mine runs a 50/50 ethanol/93 mix and he has 28% more fuel added across the map vs straight 93. I'm in the process of this changeover right now and am learning there are a lot of things I've overlooked...
Old May 10, 2020 | 03:02 PM
TheShodan's Avatar
Moderator
Correct on All Points. The BTUs of energy that petroleum -based 93 octane produces is much higher than that of ethanol based fuel. This is the reason why larger volume injectors of over 40% are needed in order to run the same power as though you were on petroleum-based fuel only
Old May 12, 2020 | 09:11 PM
so you only need injectors that's 40% bigger. So that means you only need injectors that 450cc+. I was thinking 750cc but is that to big
Old May 14, 2020 | 08:37 AM
spAdam's Avatar
Loved
Community Favorite
Well since you gave no info originally, Shodan did his best to mind read. I imagine he's about as good at it as I am.
All the things listed in previous posts. Do the flexfuel sensor. The blends do vary quite a bit. Use a minimuman S300 for your ecu. Something that can blend maps (AEM, Link, etc) will give you a tune that is much better than and ecu that only offers you a 1-d correction factor (S300). Don't expect much gain on an NA B series. You need to do your fuel lines and pump. They probably need to be replaced even if you are staying gas, honestly. Your car is OLD. There are ethanol compatible hoses and fittings available in push on form too, in case you don't want to do stainless.
I just looked this up because it's been my understanding that, by law, it must be at least 70% to be sold as E85. Didn't realize the floor was 51%, but that makes sense for regions that need winter blends. Locally I've seen it as low as 70% all the way up to 83%.
https://afdc.energy.gov/fuels/ethanol_e85_specs.html
I've also heard stories of stations in Florida, which has no real need for winter blends, offering something around 60% pretty much all the time. I suspect these stations are keeping an E85 pump to collect their tax credits but cutting it with something else to keep the pumps open between sparse deliveries.
Old May 14, 2020 | 09:05 AM
Txdragon's Avatar
My original calculations I did on the fuel before my tester came in put me at 50.6, rounding to 51%.
Turns out I was off by a lot. Lol! My volume calls here were off by about 25. I'm barely mathable enough to remember that 2+2=9.. Anywho, I noticed at the pump the next day they had a certification sticker that said 70% and when my actual test kit got here, it checked out to 75% and has been beautifully consistent at that rate for the last 50 gallons.
Old May 21, 2020 | 03:01 AM
NVturbo's Avatar
O.G. triple O.G.
Get at least 1000cc and be done with. You will be complaining when your duty cycle reaches 90% with those smaller injectors. All motor, that's fine. F/I...go bigger. That's usually the rule of thumb.
mrbuff91
Engine Management and Tuning
Sep 23, 2009 09:29 PM
NBP01LS
Nov 22, 2006 06:09 AM
digital sol
Nov 1, 2004 06:08 PM
11psiTurboSI
Oct 14, 2003 02:16 PM
