94 LX fast surge, video
Old May 2, 2020 | 12:25 PM
rickkane's Avatar
Default 94 LX fast surge, video
What's up everyone!?
My uncles 94 Accord has an idle issue that I haven't experienced. It surges from 1000-1200 RPMs very quickly when it's cold and the check engine light comes on. Codes 3, 14 and 15. When it's warm the check engine light is not on. It still does the fast surge just after start up then idles fine after about 5 seconds or so.
Changed the 02 sensor and IAC based on the dealership recommendation with no change in the condition.
Checked/cleaned/adjusted the FIT valve with no change.
Swapped map sensors - no change.
Code 14 says it could also be ECM. I'm guessing that's it since Has anyone seen this before?
https://youtu.be/Rv6a1AGYHXA
Thanks in advance!
Old May 3, 2020 | 06:54 AM
2001GSRSC's Avatar
5 Year Member
Default Re: 94 LX fast surge, video
Unless its bricked, it is not the ECM.
Repeat thermovalve adjustment procedure per manual. Place thumb over the idle port in the TB . feel whats happening there. Does plugging the hole with your thumb stop the surging?
banilejo
10
Jul 22, 2015 11:23 AM
76 camaro car
Jan 20, 2015 03:20 PM
ezzzzzzz
May 1, 2014 06:48 AM
BistaYang
10
Feb 26, 2013 10:59 AM
Dough_boi
Jul 30, 2009 11:03 AM
