Fixed p1456 error - sharing solution
Old May 3, 2020 | 09:06 PM
99stockcivic's Avatar
Default Fixed p1456 error - sharing solution
Hello everyone,
I was getting a P1456 error and a check engine light eventually coming on. After getting under the car and looking at the area in question, I couldn't see anything wrong with vacuum canister, the vacuum lines, and the CVS valve plugged into the vacuum canister checked out ok. However, I did smell fuel vapor, so I opened the plastic around the 2 way check valve, the smell was strong from there. I touched it and could see there was a little bit of fuel that might be leaking from it. Replacing that 2 way check valve was the issue. I drove almost 200 miles on it over the day and the error is now gone. Before, it would show up shortly after a second drive from resetting the errors in the computer.
For some reason, in my head, I always thought the check valve was the item plugged into the vacuum canister, I now see it the is the item next to the canister and that it has two sensor plugs into it.
Just thought I would share.
I followed these instructions for looking at and testing :
https://static.nhtsa.gov/odi/tsbs/20...53545-3978.pdf
Page 9 shows the diagram withe the location of the 2 way check valve.
dejay2014
Feb 28, 2014 11:34 PM
Lamchop0000
Mar 4, 2010 07:06 AM
existanzcivicb20
Apr 6, 2006 09:37 AM
eli_s
Mar 19, 2006 10:14 PM
Evil DOHC
Sep 24, 2001 04:36 PM
