Overheating help
Hi I have a b18c4 boosted sleeved engine.
im having problem with it overheating.
I have a 3 core half rad with shroud and fab.
new thermostat
new fan switch
new temp sensor.
1.1 bar rad cap
the gauge in the car doesn’t go past half way. Yet when I plug my smanager in the temp from cold will just continue to rise. The fan kicks and the temp will stay at 208. When driving it goes as high as 227. Then the s300 just puts the car into limp mode. I don’t know what to try next.
when I take the rad cap of there doesn’t seem to much happening with the coolant. It’s pretty steady. Should I be seeing some sort of flow. Could it be the water pump. If so how would I test This. tia
new thermostat
new fan switch
new temp sensor.
1.1 bar rad cap
new thermostat
new fan switch
new temp sensor.
1.1 bar rad cap
new thermostat
new fan switch
new temp sensor.
1.1 bar rad cap
You might have a thermostat issue.
$amGD3
Jul 26, 2010 09:24 AM
blackpearlv6
Apr 29, 2006 07:10 AM
