B16a2
Hi there
I have a b16a2 with no vtec pressure switch. Car has now a hondata p28 ecu but won’t go into vtec
do I need to bypass a4 (vtec solenoid) and d6 (vtec pressure switch) for this to work?
thanks
thanks
My goal was just to inform the OP that purchasing a used VTEC solenoid that fits his B16a2 engine would be a quick and inexpensive solution.
The casting does have the hole and O-ring recess... it just isn't drilled and tapped. You can do this and add the VTEC pressure switch, OR you can find either a "B" series or "D" series USDM VTEC assembly at your local "Pull-A-Part" or online and install that so everything plugs in. I suspect your issues are bigger than you think. Disabling the VTP in the Hondata s300 program should make things work as normal, yet you say it doesn't. So, check the solenoid, check the ECU VTEC output, engine oil pressure, make sure the pan isn't caved in on the pick-up, etc to solve the issue.
Things that make you go "Hmmmmmmm".
Asin
Jul 5, 2004 05:48 AM
