d16z6 swap won't crank but can jump starter
Old Feb 12, 2020 | 05:08 AM
bldzrr's Avatar
Default d16z6 swap won't crank but can jump starter
Hey everyone, pulled out my b16 swap and threw in my freshly built d16 vitara. I'm having a problem where the car doesn't want to crank over at all. Fuel pump primes and everything but when I turn the key to crank it just doesn't do anything except I can hear the starter click. Almost like when you don't push in the clutch when trying to start it. The car is originally auto but I converted it to manual with the b16 and everything worked so I know it's nothing to do with the wiring side of that. So I took a wire and jumped the starter to test it from the battery to the spade on the starter and sure enough it cranks. So there's a problem somewhere between ignition and starter I think? Any ideas what it might be? All grounds have been checked and cleaned, everything seems to be working except the signal to the starter. Thanks guys! Been dying to get this thing started.
Old Feb 12, 2020 | 05:46 AM
hondamark35's Avatar
Default Re: d16z6 swap won't crank but can jump starter
get the multi-meter out and start checking from the key switch to the starter solenoid, or vise versa which ever direction suits you. a good initial check though is the clutch pedal switch. the little plastic/rubber stopper pads get brittle with age and tend to crumble and split apart. you should be able to reach up under the dash and feel if it's missing. also a good sign that's the problem if the broken pieces are on the floor... been there.
Old Feb 12, 2020 | 05:53 AM
bldzrr's Avatar
I actually never wired up the clutch safety switch when I did the manual conversion for the b16. I left the shift solenoid in park and never had any issues with it starting.
Old Feb 12, 2020 | 06:55 AM
muellersfan's Avatar
Start by using a multimeter to test whether the A/T position switch^ is open or closed and whether the switch receives battery voltage when key is turned to the START postion.
Old Feb 12, 2020 | 08:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Did you use the engine harness off of the B16 swap on the replacement D16 engine ?
ProfMore
Oct 11, 2017 06:29 PM
Jeannies car
Sep 6, 2015 09:26 AM
sohctodohc
Jul 22, 2006 11:17 AM
SpoonyGSR
Jul 1, 2005 07:42 AM
slywfbpsi
Feb 9, 2004 10:35 AM
