Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Cruise control hot wiring help!!!!!!!
Old Feb 7, 2020 | 06:40 AM
Spud1237's Avatar
Default Cruise control hot wiring help!!!!!!!
Okay so before i get questions saying have you checked fuses switches blah blah etc im going to tell you yes I have replaced switches fuses relays even the main actuator under the hood with new parts and still no ****ing cruise control im at my wits end besides just to hot wire the sob up. I have a srs code 10-1 and have verified airbags are good and have replaced seat belts and seat belt clickers and still have the srs code too so im stumped I drive about 30 to 40 min on the highway every day to go to work and not having cruise is freaking killing me somebody anybody please help give me some insight.
Old Feb 7, 2020 | 10:34 AM
Spud1237's Avatar
Default Re: Cruise control hot wiring help!!!!!!!
Anyone??????
Old Feb 7, 2020 | 08:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Lets start with the Civic year, trim level, and transmission type.
Old Feb 8, 2020 | 04:32 AM
Spud1237's Avatar
Its an 04 civic ex with a ecu motor and trans from an 05 ex special edition. Manual trans came in both of them.
Old Feb 8, 2020 | 10:54 AM
Ryanthegreat1's Avatar
Plug in a proper scan tool and make sure both clutch switches are responding correctly and the brake position switch is working. More advanced tools will show cruise control log. May or may not be a function on the 05 Civic.
Old Feb 8, 2020 | 11:34 AM
Spud1237's Avatar
They seem to be fine but im not even getting a green light indicator from my switch to the left of my knee I know that switch doesnt run through the brake or clutch those are later in the circuit I have studied the wiring diagram throughly lol and I have checked the orange wire for power and it has 12 volts and ive checked the black wire for ground and it grounds out as well according to the diagram the red and redblack wire are supposed to go to the dash indicator to make the cruise light come on the dash this is where im stumped I got power and ground but no light telling me its on and i have three of those switches 2 used and one brand new one used one is confirmed working as i took ot out of a wrecked car that still drove and tried the cruise out in it and it worked perfectly fine
Old Feb 8, 2020 | 12:50 PM
Spud1237's Avatar
Also I have a Bluetooth obd2 dongle could you recommend an app that has that function? Or is that based on the obd2 dongle itself.
Old Feb 11, 2020 | 05:57 AM
Spud1237's Avatar
So nobody has any idea how i can trick the cruise into thinking everything is fine?
Old Feb 11, 2020 | 09:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
What you have stated, with respect to your testing, would suggest that the cruise control system works. This means that you have missed something: tested incorrectly or made assumptions that are factually untrue. I suggest you Google a FSM for your application and follow the trouble-shooting flow chart to the "T". You will discover the problem. The cruise control system in your vehicle is NOT that complicated.
Old Feb 12, 2020 | 05:35 PM
muellersfan's Avatar
Originally Posted by Ryanthegreat1
...make sure both clutch switches are responding correctly and the brake position switch is working.
Focus here^
This involves using a multimeter to ensure the cruise control computer is appropriately receiving and lacking signals from the pedals.
Old Feb 13, 2020 | 03:45 AM
Spud1237's Avatar
Can you give me some insight on what i should look for voltage wise?
Old Feb 13, 2020 | 06:06 AM
You are not getting the cruise main switch to turn on? That is going to be step one. That should light up no matter what the clutch and brake switches are doing.
Old Feb 13, 2020 | 04:18 PM
Given the SRS code, the cable reel would be a suspect.
These diagrams may help:
Old Feb 19, 2020 | 05:43 AM
Spud1237's Avatar
Sorry i havent posted back in a while I just about gave up but due to my job being so far away its aggravating me again lol what is an fsm? I would love to get my hands on a detailed troubleshooting guide so I can test for exact voltages and resistance and see where my issues are occurring. But as ryan stated the light doesnt even light up on the main switch and I have verified voltage on the orange black wite and ground to be between 12 and 14 volts depending if the car is running or not.
Old Feb 19, 2020 | 07:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
FSM = Factory Service Manual. You can order them from your local Honda Parts Department or directly from Helminc.com.
Old Feb 23, 2020 | 05:01 PM
Spud1237's Avatar
Okay I got my hands on a factory service manual and it only has one page regarding the cruise control and its of the same diagram I got off the internet lol. Does anyone know what voltage should be on the red and red black wire? Or is that for illumination only and have nothing to do with the cruise working?
Old Feb 24, 2020 | 05:55 AM
If the Blk/Orn wire has battery voltage, then the main switch may be bad or the ON/OFF bulb in the switch is bad.
Old Apr 14, 2020 | 03:53 PM
Spud1237's Avatar
Okay guys sorry its been a while but i finally started to look into it again. I had bought a radio and installed in my civic when I realized they had a red or a red/blk wire (cant remember lol) hooked up to a speaker wire. Which is a illumination wire. Dumba$$3$. I fixed it and bought a new switch and walah I got a light lol. But the cruise still does not work and I do not have a light on the dash. Where else do those red and red/blk wires go? Does anyone know? I might be able to chase down what else they could have fried.
captainstoob
Honda Civic (2006 - 2015)
Jul 9, 2016 04:48 AM
cazper51
Nov 22, 2010 02:38 PM
91akira
10
May 8, 2009 11:22 PM
Daleford
18
Jun 23, 2007 07:57 AM
a1320addict
Audio / Security / Video
Feb 18, 2006 03:49 AM
