98 auto d16y8 swap with 92 manual b15d7
I live in Memphis Tn. emissions won't be a problem. I need to know what all I have to swap. I believe it would be going from OBD2 engine w vtec into OBD1 non vtec.
tired of searching
Well, I got to d16y8 into the car. It being obd2 I used the harness off the d15, switched alternator, the d15 dizzy bolted right up and worked fine for the Vtec. So I turned an obd2 motor into and obd1 motor. It won’t look for a knock sensor, so no check engine light. I used the automatic intake and had to drill and tap to add Iacv and I used the obd1 throttle body from the d15. I had the po6 chipped with a y8 base map and converted it from auto to manual trans mission. Pretty much ran for a couple of minutes then threw a rod. So, now I’m moving on and swapping in a B18b1. Thanks for all those whom added intelligent content to this thread. Two brains are better than one. We are a hive mind. Honda’s for life.
xsaxisx
Apr 27, 2011 08:03 PM
haroldthefly91crx
Sep 13, 2006 04:35 PM
