Brake System Concerns
Old Dec 19, 2019 | 06:13 AM
Sielu1995's Avatar
Default Brake System Concerns
First, I apologize if this is in the wrong place but I need help finding the right solution so history doesn't repeat itself. I know the market is ever changing so I'm planning out what to do before I buy a Civic or Del Sol in a few months
I've owned a 93 Del Sol SI, 99 Civic EX couple and 99 Integra GSR and the one problem I always had, especially in heavy traffic or when shooting the back roads was rapid brake wear and in 2 cases of OEM brakes, overheating the rotors to the point of turning the rears blue and the fronts black and cracking/crumbling the pads. I've tried Brembo rotors and Akebono composite pads with decent results.
Old Dec 19, 2019 | 07:09 AM
tony_2018's Avatar
Fish Twig
Default Re: Brake System Concerns
make sure your guide pins are lube
make sure your wheel bearings aren't fucked
make sure you bleed your brakes properly and in order
Old Dec 19, 2019 | 08:06 AM
Sielu1995's Avatar
Makes good sense. Is simply upgrading to better pads and rotors all I need or is it worth it to step up to a larger, higher capacity system? This I ask not just for durability and consistency but also because my 2 1/2yo daughter will sometimes be with me.
square_1
May 1, 2007 10:39 AM
ivicr
11
Oct 5, 2006 10:03 PM
Ch3miztry
Mar 17, 2005 04:46 PM
memphisraines26
May 14, 2003 07:02 PM
TXDelSol
22
Feb 18, 2003 07:24 PM
