Timing belt issues with the rear cam
Old Dec 2, 2019 | 02:03 AM
Patrick Saenz's Avatar
Default Timing belt issues with the rear cam
Ran into a problem I'm not to sure about the rear cam jumped way ou of time during the timing/ water pump swap, does it matter if I take the cam clock wise all the way back around or do I need to go counter clockwise for the correction?
Old Dec 2, 2019 | 03:13 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Timing belt issues with the rear cam
which motor??
Old Dec 2, 2019 | 04:13 AM
Originally Posted by NVturbo
which motor??
3.5 liter v6 2011 honda accord .
Old Dec 2, 2019 | 08:38 AM
which motor??
I went ahead and just went clockwise with it I didn't hear anything unusual but it did a good lunge at one point and then I had to back up slowly to get it on the timming mark , put the belt on and turned the crank twice but the crank shaft pulleys are not falling in time with the crank shaft , am I missing something here
Old Dec 2, 2019 | 08:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I'm assuming you are turning the cam with no timing belts/chains attached to set mechanical timing. If so, you can turn the cam any direction you want IF you put the crank a quarter turn from TDC. This will lower and raise the pistons to half way and you will not be able to create a valve to piston contact. After adjusting the cams to TDC, then you move the crank back to TDC the quarter turn and install belts/chains to set mechanical timing.
However, its always a little nicer on the motor and cams to turn them in the direction they usually rotate so all pads/rollers rub the usual spots on the lobes of the cam etc.
Old Nov 10, 2020 | 07:48 AM
Thanks for the help yall I got it eventually shes running beautifully changed the spark plugs and trans fluid and she runs like new.👍
willyjoejr
Jan 4, 2019 03:04 PM
hypnolobster
Jan 24, 2012 08:53 PM
Smash03
Apr 25, 2010 04:13 PM
chrisknight
Dec 9, 2005 02:03 AM
brockscivic
Jul 6, 2004 10:07 AM
