Matteggy's theory on using "Longer Rods" for turbocharging. Good idea, or No?
I’m building my daily B18b1 for boost. Going for a full rebuild. Because it’s a daily and I intend to put a lot of mileage on it, I wanna raise the rod ratio even if it’s only slightly so I was thinking about longer forged eagle rods. It’s either this or darton sleeves to handle the lateral forces better. I just wanna know if anyone has any experience with longer forged rods on boost? Want to make sure I won’t be compromising motor integrity drastically
Thanks in advance!
Thanks in advance!
Longer rods make the engine last longer doesnt compromise its lifespan.
Youll need custom higher pin pistons..
And yes, its completly not necessary.
Go darton.
Go darton.
As stated don't bother getting custom longer rods and adjusted pistons to increase the R/S ratio. Do a CSS block or full-sleeve like Darton and any reputable rod/piston combo.
B18B's do wear the side of the bore (thrust loading) - its a given fact, but not to the point where its failure prone.
Even though the B18B has a poor R/S on paper - the engines are amazingly strong and rev happy when using the right parts.
I have already found eagle rods that are slightly longer than stock, isn’t there a piston made for that application?
I have really long rods in my B19C5/1 engine. As stated above by Balor Gr and extremeracer, longer rods aren't really necessary and although scientifically increasing the rod-stroke ratio will reduce side loading... there are other improvements to fortify the block that will be money better spent. Sleeving would be one. Now, you have mentioned that you have Eagle rods that are "slightly" longer than the stock rod... does this mean that you have a set of the 5.404" LS rods or something longer ?
