B18C Piston and rod Q's
Old May 27, 2010 | 06:29 AM
zsoccerdude17's Avatar
Default B18C Piston and rod Q's
I decided to go turbo with my B18C1/90 Hatch build. I just have a question on the piston rod combo. Being as i have to bore this thing because of a previous stock piston ring land failure I'm looking to get Wiseco pistons (part # K541M815 ), with either eagle rods or Manley rods (part # 14026-4). I believe the manly rods are probably a little better, but my confusion was on the multitude of part #s from eagle which from what i can tell is a difference in length. Is there a way to tell what length I would want if I went the eagle route? And what are peoples experiences with both the Manley and eagle rods. Input is appreciated.
Old May 27, 2010 | 06:47 AM
kyden's Avatar
Default Re: B18C Piston and rod Q's
you want 5.433" rods. thats factory length.
i would spend the little extra for manley rods, its not that much more.
Old May 27, 2010 | 06:48 AM
DA TeG 90's Avatar
Eagle/Manley rods are both great rods. Eagle is more for the "budget" build as they are very cheap. Not knocing the brand at all as about more then half on honda tech use them. After 550whp though is when you might want to start looking into another set up rods. That is where manley / pauter, etc come in.
I am not sure of which part number of the manley you gave, but I know there is 2 sets of them. There is just the reg, manley which is alot like the eagle, and then there is the manley turbo tuff rod which is more good for 800+whp. It's pretty much what your build is going to look like/ how much power you want to make.
If your looking to make anything under 550whp, I would go with eagle. Anything past 550+whp, I would go with Manley, or Pauter. Hope that helps!
Old May 27, 2010 | 08:25 AM
Well originally this started a simple NA build...but then i got a new job :D. SO now i have the money to afford good stuff, and im wanting to get around 500 hp but i dunno how possible that is, i would be satisfied with 300 to 400.
im thinking around 12lbs puts me around 300 range, but i want to boost 20. I will have a deckguard as well. Its not a DD by any means, more of a weekend warrior. Will this combo hold 20 lbs reliably?
Old May 27, 2010 | 09:24 AM
After thinking it over a bit, being my first turbo build, i think ill stick with 12psi and I can always go up as i gain more knowledge and experience.
Old May 27, 2010 | 10:01 AM
kyden's Avatar
don't bother with a block guard.
Old May 27, 2010 | 10:20 AM
RealStreet's Avatar
Those are the correct part #s for you. 14026-4 and K541M815. That is Turbo 81.5mm pistons and Rods for a B18C. Let us know if you need any help
Old May 27, 2010 | 10:31 AM
AlexDphoto's Avatar
Im running an 81.5mm Wiseco/Eagle combo and its excellent!
Old May 27, 2010 | 11:47 AM
haha thats funny i was gonna order them off your ebay store, 500 shipped sounds like a pretty good deal to me for the pistons, PM me if its easier to just go strait through you.
Old May 27, 2010 | 11:56 AM
RealStreet's Avatar
Yeah the combination of pistons/rods is more but I will send you a PM right now.
Old May 27, 2010 | 12:16 PM
Ammadien's Avatar
Great info, gonna be looking into redoing the bottom end of my gsr motor for a turbo build too in the near future.
Gonna be talking to RealStreet too in a bit.
Nate
Old Aug 6, 2012 | 05:01 PM
4doorGSR2.0's Avatar
I am looking for a great deal on some eagle rods. i paid someone for them locally and they haven't come through i've spent alot on other parts and its killing me not being able to finish my project after 2 months all machine work done and everything waiting on rods and GSR crank got ACL bearings waiting on them plz let me know if u know of a good deal thanks
Old Aug 7, 2012 | 06:39 PM
Hyper16-Johnny's Avatar
Depends if you're talking about H-beams or I-beams. If H-beams, then Eagle are a better choice because of price, they would also yield approx same power as Manley H-beams. If I-beams then the Turbo Tuffs would be choice because best bang for buck and proven to work, then again Eagle doesn't make I-beams for us.
Eagle H-beams approx $300-340
Manley H-beams approx $350-400
Manley I-beams (aka Turbo Tuffs) approx $750-800
Old Aug 8, 2012 | 06:59 AM
kyden's Avatar
they can hold the same power, but the manley units are machined a lot better.
RACEPAK
Sep 14, 2010 03:00 PM
DeleriouS25
Aug 15, 2007 08:15 PM
Retired
Dec 14, 2005 09:00 AM
queez
Jun 24, 2003 06:43 PM
