Compression tests:
Old Nov 14, 2002 | 07:58 PM
ChaseIntegra's Avatar
Default Compression tests:
How do YOU all do your compression tests? I have heard a couple of different ways to do it. How do you do it on YOUR car?
Old Nov 14, 2002 | 08:19 PM
boostinb18's Avatar
Default Re: Compression tests: (ChaseIntegra)
car must be warm... take out all spark plugs....put comp tester in.... floor gas and crank over like 5 times.... do this 3 toimes on each cylinder... take highest number.
Old Nov 14, 2002 | 11:14 PM
deleted's Avatar
Default Re: Compression tests: (boostinb18)
I agree, plus remove the FI fuse so that no fuel is being injected into the cylinders when cranking.
More info here: http://www.c-speedracing.com/howto/c.../comptest.html
Old Nov 15, 2002 | 01:38 AM
00 FBP ItR's Avatar
do it at WOT
Old Nov 15, 2002 | 09:35 AM
Default Re: Compression tests: (00 FBP ItR)
thanks guys, I will try it again that way.
EdwinCheng
May 8, 2014 02:26 PM
hpi247
Aug 2, 2007 06:27 AM
one bad dx
Jan 4, 2007 09:55 AM
wm5holla
Mar 23, 2003 03:39 PM
b18c5T
Jan 29, 2002 09:08 AM
