Compression test=bad news
Old Jan 28, 2002 | 11:21 PM
b18c5T's Avatar
New User
Default Compression
Modified by b18c5T at 4:00 PM 10/30/2005
Old Jan 28, 2002 | 11:54 PM
DLB1994's Avatar
Default Re: Compression test=bad news (b18c5T)
where u live in richmond i never seen a turbo itr in richmond
Old Jan 29, 2002 | 12:38 AM
LsTurbo91's Avatar
Default Re: Compression test=bad news (DLB1994)
whats with all these R's popping motors lately?
Old Jan 29, 2002 | 02:34 AM
Cyber ITR's Avatar
Default Re: Compression test=bad news (LsTurbo91)
what cause compressions to dropped and sometimes no compression at all ??
thanks
Old Jan 29, 2002 | 02:54 AM
qwkteg125's Avatar
how did you perform the test? did you crank at WOT? how many times did you crank? did you have all plugs removed before you cranked?
Old Jan 29, 2002 | 05:51 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Compression test=bad news (qwkteg125)
You can get the eagles from importparts.com for I think $350.
VTC_CiViC's Avatar
Default Re: Compression test=bad news (Arturbo)
Are those supposed to be factory compression numbers or are you running lower CR?
Old Jan 29, 2002 | 07:02 AM
boost killz's Avatar
New User
Default Re: Compression test=bad news (VTC_CiViC)
Make sure that your compression tester is still functioning properly and all air is sealed on the connecting joints of the tester. If your compression was so poo pooy then there would be no reason why the car should pull so hard and at stock compression you should be seeing well over 200 on each cylinder, not sure of exact range bnut definitely over 200 and remember to remove FI fuse to not flood the engine with fuel. Good luck and I would try a second tester. BTW any reason in particular you did the test? Or was it just routine check up. Peace.
Nick
Old Jan 29, 2002 | 07:11 AM
GruvyTune's Avatar
New User
Default Re: Compression test=bad news (boost killz)
where is the FI fuse located. Is it under the dapoo pooried to find it but got confused the last I tried to remove mine.
should you leave the other spark plugs in when you check a cylinder?
tf
Old Jan 29, 2002 | 07:15 AM
VTC_CiViC's Avatar
Default Re: Compression test=bad news (GruvyTune)
I don't know about Teg's, but when I pulled the FI fuse from my Civic, it also disabled the ECU altogether, so you might want to pull the fuel pump fuse in the cabin fuse panel, worked for me
Old Jan 29, 2002 | 07:16 AM
New User
FI fuse on my gsr or any other for that is in the engine bay at the fuse box next to the battery, and remove all spark plugs and cables. BTW make sure to hold throttle open completely when cranking the engine over.. Hope that helped
Nick
Old Jan 29, 2002 | 09:08 AM
Type-ARR's Avatar
man that sucks....
EdwinCheng
May 8, 2014 02:26 PM
Nisif
Apr 12, 2005 09:13 AM
builtprelude
Jan 22, 2004 10:49 PM
wm5holla
Mar 23, 2003 03:39 PM
