Re: Using moresso oil pan with turbo does this line look okay?
Originally Posted by NVturbo
is that hose rated for higher temp applications?
Came with the block when I bought preowned forged piston rod shortblock turbod not sure
. I will replace the hose but the angle is what I’m inquiring about honestly that angle okay. Or should I cut the flange on turbo side a little shorter
^^^ I, myself, can not POSSIBLY stress this one enough. Get a good return hose. Or you'll wind up having THIS **** happen..
I was on the road and driving when my oil light flickered, then came on solid. I pulled over to see I had no oil and saw the return hose had split. This was after about 800ish miles post rebuild startup. The hose was brand new too. Get the heavy duty Gates hose and put any worry behind ya!
