Fuel presure drops 5psi/hunting idle. turbo k24 DC4
Old Aug 25, 2019 | 12:33 PM
B_Swapped93's Avatar
Default Fuel presure drops 5psi/hunting idle. turbo k24 DC4
  • 98 dc4 K24/20 6266
To start: the pressure drops at the exact time the idle does, drops about 5 psi and the idle drops a good 1K RPM. Brand new ID 1050x, 6an feed/return, ktuned FPR set to 43.5 psi, the fuel pump is the bone stock 98 Rs(80 lph) one. Kpro set to 1000cc and dead time set from the pull menu to DW 1000cc. It will idle fine at start up then 10 seconds later it starts hunting, car uses an electric eater pump/tucked rad set up and ktuned filler neck so bleeding was easy. Brand new Ktuned 4bar map and acuity tps. Ktuned tucked harness so I KNOW I didn't mix anything up.
This idle is one of the last things stopping me from doing a shakedown and getting it tuned
Old Aug 25, 2019 | 02:01 PM
Txdragon's Avatar
Default Re: Fuel presure drops 5psi/hunting idle. turbo k24 DC4
Do the DW injectors have the same dead time as the IDs? Sounds like all this will be ironed out when you tune it.
Old Aug 25, 2019 | 03:03 PM
To be honest I don't know enough about that to remotely say, I just used the pull down menu in kpro and all they had listed was DW injectors/stock. I'd just like to run it up and down the rd to make sure it has no real issues and end up being kicked off the dyno kinda of thing. I can post a vid tomorrow, but it just revs up and down by a good 1000 rpm till you turn it off.
Old Aug 25, 2019 | 04:03 PM
Txdragon's Avatar
This could be any number of problems but I'd say as of now, it could be whatever basemap you're trying to run also.
Old Aug 25, 2019 | 07:14 PM
Should mention this is with the Ktuned 90mm TB and 90mm Ktuned intake manifold. Closed the throttle plate as much as I physically could and re scaled the TPS and it doesn't hunt anymore. Starts off at 1400, then goes slowly to 1800ish and just stays there till you blip the throttle then it goes 1400 for a while. Sounds perfectly find when you rev it no stuttering or poping etc. guess that's aceptable
Old Aug 28, 2019 | 06:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
You should be able to lower or raise the Idle in Smanager or the Kpro, on Hondata S300 under IDLE TAB I can move the dial from high to low and it will raise or lower the idle. When I was sent my base map I had a high idle and checked that tab and it was almost turned all the way up, my idle was at like 1300 then I moved the dial to NORMAL and the idle dropped to 950.
LstecEk
Mar 21, 2014 03:00 PM
welfarepc
Sep 13, 2007 05:15 PM
ExVtec
May 16, 2004 07:48 PM
BoostedD15B7
Nov 12, 2003 05:53 PM
asianspeed
Feb 25, 2003 07:19 PM
