Why is my ECT wire 12v?
Old Aug 19, 2019 | 01:33 PM
RadertheRealtor's Avatar
Icon5 Why is my ECT wire 12v?
I have a 1998 civic with a 1994 gsr engine/ecu. The civic harness is used and I have a premade jumper plug (the $20 version you can buy on ebay etc.) to go from obd2 harness to my obd1 ecu. I am getting code 6. I have replaced the sensor and ecu and still have the code. My sensor is reading around 2000 ohms. I have read a bunch of threads and it seems like the wire should be 5v. Mine is reading 12v with wire unplugged from the sensor and key on.
Anyone know why it's 12v?
How do I get it to the needed 5v?
What else am I doing wrong here?
Thank you
Old Aug 19, 2019 | 11:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Why is my ECT wire 12v?
Check continuity of the red/white wire between the ECT sensor and the ECU. Then make sure the green/black wire is a ground.
Old Aug 20, 2019 | 03:20 AM
7rrivera7's Avatar
Do you have the original OBD2 ECU? If so plug it in and see if the code goe away. This will isolate the problem to the harness or OBD1 ECU
Old Aug 21, 2019 | 01:05 PM
I will check the continuity and ground. Thank you
Old Aug 21, 2019 | 01:06 PM
I do not have the obd2 ecu. I bought the swap this way. Good point though...
Old Aug 22, 2019 | 10:40 AM
This was very helpful, thank you. I had the wrong plug on the ect. I didn't do the swap so not sure of all the schematics. I appreciate you mentioning wire colors b/c that's what clue'd me in. Silly mistake but glad it's fixed!
Old Aug 22, 2019 | 06:13 PM
wunfstgsr's Avatar
Loved
Community Favorite
Did you have the vtec pressure switch on there?
Old Aug 22, 2019 | 08:40 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Glad you found the problem... always happy to help.
Old Aug 26, 2019 | 08:01 AM
Yes. Whoever did the swap made the harness to where the correct vtec pressure switch plug doesn't reach so I assumed I had it correct b/c one reached and the other didn't. Lost a lot of time on this but at least it's corrected now.
BlackCivicEX
32
May 10, 2023 02:04 AM
efdave
Jan 13, 2019 06:33 PM
ferio-ichi3
Jul 13, 2015 09:39 AM
eastbay92cx
Aug 30, 2004 06:51 AM
