1995 Del Sol Si fuel troubles
Old Jul 10, 2019 | 04:58 AM
ChumbusBees's Avatar
Default 1995 Del Sol Si fuel troubles
The car won't send power to the fuel pump while cold. If I start it with starter fluid, the problem is fixed for the day.
Quick list of things I've done trying to fix this.
-replaced fuel pump and filter
-pulled injectors and cleaned them
-replaced main relay. Yesterday it wouldn't start at all on the old relay, but it fired right up with the new one.
This is my first car I've worked on. At this point it's just absurd. I'm pretty much totally stuck.
Old Jul 10, 2019 | 06:33 AM
muellersfan's Avatar
Default Re: 1995 Del Sol Si fuel troubles
Sounds like a bad ECU. If so, you can either replace the ECU or the ECU electrolytic capacitors.
Start by opening the ECU to inspect the printed circuit board. A swollen or leaking capacitor is generally a bad capacitor. You can also desolder the capacitors and measure their capacitance with some types of multimeters.
Old Jul 10, 2019 | 07:10 AM
Good thought. I looked up how to reset it on a whim. Fuses are out now, just gotta wait for 10 minutes apparantly.
Can you help me out with the location of the ecu? I know it's behind the glovebox, but I don't know how to proceed.
Old Jul 10, 2019 | 07:15 AM
ECU is behind the passenger kick panel.
Old Jul 10, 2019 | 07:24 AM
Reset actually worked! Praise Jeebus, there was no way I could afford an ECU. Thank you so much.
Old Jul 10, 2019 | 09:11 AM
I hope you are right, but problem will likely recur.
Old Jul 10, 2019 | 09:39 AM
I will be on alert.
Old Jul 10, 2019 | 09:51 AM
I will be on alert.
Best of luck!
Old Jul 11, 2019 | 10:08 AM
Of course that didn't work. If it's the ECU, then the car is basically scrap metal to me. Starting to hate this wonderful little car.
Old Jul 11, 2019 | 11:02 AM
If there is something wrong with it, it's not visible
Old Jul 11, 2019 | 12:43 PM
The cost of an electrolytic capacitor, which generally go bad to cause the type of problem you are having, literally cost pennies.
Old Jul 11, 2019 | 12:51 PM
DaX's Avatar
DaX
Loved
Community Favorite
If you don't feel up to the task of replacing the capacitors yourself, you can send it to Hondata and they will do it for $50.
Old Jul 11, 2019 | 12:55 PM
Well at least I have an idea what it is.
Old Jul 11, 2019 | 12:56 PM
I circled examples of electrolytic capacitors in your ECU. Inspect all of them for swelling (generally at the top) and/or leakage (generally at the bottom). Any of these abnormalities indicate a bad capacitor.
However, not all bad capacitors can be identified by inspection. In this case, you need to desolder them from the printed circuit board and measure their capacitance. Some multimeters are able to measure capacitance, but make sure the capacitance rating is not higher than the micro-farad limit of the multimeter.
I believe that one of the two capacitors marked by an asterisk controls the fuel pump.
Watch some YouTube videos on desoldering and resoldering capacitors on a printed circuit boards (PCB). It's easier than you think.
I buy replacement capacitors here:
https://www.mouser.com/
Old Jul 11, 2019 | 01:00 PM
I guess I'll post back here when I have a soldering iron then.
edit: found the 2 bad capacitors. They have corrosion on the board stemming from them.
Old Jul 11, 2019 | 01:05 PM
And watch the YouTube videos!
Old Jul 11, 2019 | 01:06 PM
Is one a capacitor I marked by an asterisk?
Please post pics to show some nice examples for other members.
Time Ranger
11
Aug 4, 2014 03:07 AM
Wrestler-Dustin
35
Nov 27, 2013 08:15 PM
CDangerfield
Jul 20, 2012 06:55 AM
sgnlab
May 28, 2012 08:26 PM
guitarma
Sep 26, 2011 12:46 AM
