1995 Del Sol Si fuel troubles
Old 07-10-2019, 04:58 AM
Default 1995 Del Sol Si fuel troubles
The car won't send power to the fuel pump while cold. If I start it with starter fluid, the problem is fixed for the day.
Quick list of things I've done trying to fix this.
-replaced fuel pump and filter
-pulled injectors and cleaned them
-replaced main relay. Yesterday it wouldn't start at all on the old relay, but it fired right up with the new one.
This is my first car I've worked on. At this point it's just absurd. I'm pretty much totally stuck.
ChumbusBees is offline
Old 07-10-2019, 06:33 AM
muellersfan's Avatar
Default Re: 1995 Del Sol Si fuel troubles
Sounds like a bad ECU. If so, you can either replace the ECU or the ECU electrolytic capacitors.
Start by opening the ECU to inspect the printed circuit board. A swollen or leaking capacitor is generally a bad capacitor. You can also desolder the capacitors and measure their capacitance with some types of multimeters.
muellersfan is offline
Old 07-10-2019, 07:10 AM
Good thought. I looked up how to reset it on a whim. Fuses are out now, just gotta wait for 10 minutes apparantly.
Can you help me out with the location of the ecu? I know it's behind the glovebox, but I don't know how to proceed.
Old 07-10-2019, 07:15 AM
ECU is behind the passenger kick panel.
Old 07-10-2019, 07:24 AM
Reset actually worked! Praise Jeebus, there was no way I could afford an ECU. Thank you so much.
Old 07-10-2019, 09:11 AM
I hope you are right, but problem will likely recur.
Old 07-10-2019, 09:39 AM
I will be on alert.
Old 07-10-2019, 09:51 AM
I will be on alert.
Best of luck!
Old 07-11-2019, 10:08 AM
Of course that didn't work. If it's the ECU, then the car is basically scrap metal to me. Starting to hate this wonderful little car.
Old 07-11-2019, 11:02 AM
If there is something wrong with it, it's not visible
Old 07-11-2019, 12:43 PM
The cost of an electrolytic capacitor, which generally go bad to cause the type of problem you are having, literally cost pennies.
Old 07-11-2019, 12:51 PM
DaX
DaX's Avatar
If you don't feel up to the task of replacing the capacitors yourself, you can send it to Hondata and they will do it for $50.
DaX is offline
Old 07-11-2019, 12:55 PM
Well at least I have an idea what it is.
Old 07-11-2019, 12:56 PM
I circled examples of electrolytic capacitors in your ECU. Inspect all of them for swelling (generally at the top) and/or leakage (generally at the bottom). Any of these abnormalities indicate a bad capacitor.
However, not all bad capacitors can be identified by inspection. In this case, you need to desolder them from the printed circuit board and measure their capacitance. Some multimeters are able to measure capacitance, but make sure the capacitance rating is not higher than the micro-farad limit of the multimeter.
I believe that one of the two capacitors marked by an asterisk controls the fuel pump.
Watch some YouTube videos on desoldering and resoldering capacitors on a printed circuit boards (PCB). It's easier than you think.
I buy replacement capacitors here:
https://www.mouser.com/
Old 07-11-2019, 01:00 PM
I guess I'll post back here when I have a soldering iron then.
edit: found the 2 bad capacitors. They have corrosion on the board stemming from them.
Old 07-11-2019, 01:05 PM
And watch the YouTube videos!
Old 07-11-2019, 01:06 PM
Is one a capacitor I marked by an asterisk?
Please post pics to show some nice examples for other members.
  • Ask a Question
Question Title:
Description:
