1995 Del Sol Solid CEL/ fuel pump won’t turn on when wet out or humid
Old May 29, 2019 | 06:34 AM
Kenny Parham's Avatar
Default 1995 Del Sol Solid CEL/ fuel pump won’t turn on when wet out or humid
Warning: Not a professional, but not stupid, maybe.
So, I’ve been trying to track down the source of my fuel pump not working. I read in other threads it could have been the distributor, spark plugs or lines. I replaced all of them. I thought the fuse box was getting wet or a bad connection but went through it all and all tested fine. I then cracked open the ECU and one of the capacitors had leaked. I bought a new one and it now starts just fine. Got mine refurbished for about $150. I’m pretty sure it’s the atmospheric pressure that made it stop working. If I went up in elevation or the weather was bad (rainy/cloudy weather) the pressure would be low and make it not work. Would also cut out while driving.
Let me know if I’m on to something or just going crazy. Thanks.
Old May 29, 2019 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1995 Del Sol Solid CEL/ fuel pump won’t turn on when wet out or humid
So, you bought a new ECU and the car works properly. You then got your original ECU repaired and it works "sometimes" ???
Old May 30, 2019 | 08:46 AM
Sorry, should have edited that last one. I bought a refurbished one online for about $150 because my old one only worked sometimes. The one I bought works properly.
Wrestler-Dustin
35
Nov 27, 2013 08:15 PM
stiles
12
May 12, 2012 06:33 AM
guitarma
Sep 26, 2011 12:46 AM
EdSales
Mar 23, 2010 09:41 AM
