Too much $ ???????
Old May 29, 2019 | 02:50 AM
hondaslave1342's Avatar
Default Too much $ ???????
I've been looking for a SH model for a bit now..I can get a 1999 SH with 126k...one owner...Black...no dents..clean..the person is set and stuck at $4500..is this a fair price..thanks in advance
Old May 29, 2019 | 05:55 AM
Ryanthegreat1's Avatar
Default Re: Too much $ ???????
Probably reasonable if everything is in order and it has a fresh timing belt and is not leaking oil.
Old May 29, 2019 | 10:35 PM
TimiK's Avatar
10 Year Member
depends about maintenance history
Old May 30, 2019 | 02:29 AM
Thanks..I got to talking with the guy..original owner..but does not have a single..not one..piece of history on this car..if I bought a new car..spent 28k in 1999..I would keep everything....
Old May 30, 2019 | 11:53 PM
TimiK's Avatar
10 Year Member
doesnt sound right
Old May 31, 2019 | 09:43 AM
Prudz_lude's Avatar
Not uncommon for original owners to not keep any history. If it is as clean as it looks, pay for an inspection and if checks out the pay the man the money if you really want it. Not many 1 owner, clean title stock SH preludes floating around there with low km.
Old May 31, 2019 | 10:07 PM
TimiK's Avatar
10 Year Member
that just means he have to start newing everything if he buys it - clutch, timing things, spark things, new filters, new fluids and so on.... so take that in mind
without maintenance history you can easily offer 1000 less what the guy is asking
do leak and compression test first and check whole body for rust and does engine is dry from oil (probably have to see the car also from below)
Old Jun 1, 2019 | 05:13 AM
I passed..the guy modified the add and now wants 5k..
Old Jun 1, 2019 | 09:57 AM
Prudz_lude's Avatar
You are literally describing a pre-purchase vehicle inspection. Which is what I suggested. Just because someone doesn't have paperwork does not mean work has not been completed and does not mean everything suddenly needs to be replaced. If someone doesn't have paperwork, inspect the vehicle at a shop if you aren't confident in what you are looking at.
Old Jun 1, 2019 | 09:05 PM
TimiK's Avatar
10 Year Member
it kinda does - otherwise you cannot know for sure and you have to do it
shops will tell you this also because they are not sure either
Old Jun 2, 2019 | 06:17 AM
Thanks everyone for the valued comments..I passed..the guy was fishy..
Ty Dyer
Feb 26, 2017 02:58 PM
willnfrank
Jul 9, 2013 08:23 AM
Macker1
Jun 5, 2011 10:33 AM
mill1640
Oct 20, 2009 04:10 PM
04Si
May 23, 2007 01:36 PM
