Best mounts for daily driver b20 in 94 ej?
Old May 23, 2019 | 03:15 PM
Richard Rand's Avatar
Default Best mounts for daily driver b20 in 94 ej?
I’m shopping for mounts for my b20/ej swap but all the performance mounts typically state that it will increase the amount of vibration from the motor to the chassis.
Im hoping to find a mount for a daily driver style swap. Any one know if Hasport or Innovative has a soft rubber?
Old May 23, 2019 | 06:47 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Best mounts for daily driver b20 in 94 ej?
I recommend Hasport 62A mounts.
Old May 24, 2019 | 09:12 AM
Freedo_Civegra's Avatar
I’ve got the 62A Hasport mounts in my J-swap, and the vibrations are not really noticeable at all.
Old May 24, 2019 | 10:34 AM
acmoc's Avatar
It's all in perspective.
60a innovative 62a hasport is like stock to some, too much for others.
Some people run(or say they run) 80a mounts.
Some have stock engines. Others have lightened flywheels, crank pulleys, strut bars, roll cages, full interior, no interior, stock exhaust, straight pipes, idle raised to 1k.
Some people drive their cars once a month. You said yours is a daily.
There's way too many threads on this topic.
Bottom line. poly mounts will vibrate. Way more than stock. Even drone
Stock mounts are rubber, stock mounts have hollows.
Poly mounts are harder and solid.
Get the softest durometer because it will be more than enough. Unless you're building a 900 hp drag car.
Yes, they break in and get softer. But never like stock, not even close. And in cold weather they'll feel just like new again.
Yes, bolts can back out from the vibration.
Yes, there's performance benefit, but is the discomfort really worth the 1/4 second
People will come in here and say that 80a is not bad, some will say 60a is not bad, some 60a will be hell.
Old May 24, 2019 | 12:07 PM
tony_2018's Avatar
Fish Twig
@acmoc can 3d print you some inserts.
Old May 24, 2019 | 12:39 PM
acmoc's Avatar
Get some window weld and fill your front/rear torque mount and transmission mount. The engine mount literally does nothing but hold it. That's why it has the weakest design. t also transmits most of the nvh. That's why it's the weakest design and or liquid fllled.
Old May 24, 2019 | 08:01 PM
Thanks for the information, I would like to try to maintain as minimal vibration as possible and the innovative mounts (not sure which ones) rattle the hell outta the car. These mounts were installed when I purchased the car, it already had the b20 and hydro trans. The past owner did not daily drive the car, so I’m trying to transition it into a fun commuter. I’m assuming the lower the # the softer the mount so I’ll shop a bit to find 60 of lower.
Old May 24, 2019 | 11:27 PM
Contact your mounts’ manufacturer about replacing the mount inserts with a softer durometer material. Might be cheaper for you, but you’d need to send in your current mounts.
Old May 25, 2019 | 06:35 AM
acmoc's Avatar
innovative mounts are color coded. What color are the bushings?
Old May 25, 2019 | 10:15 PM
egsleepercivic's Avatar
why not oem or oem replacements for a 94+ integra or Civic ex\si
is the drivers side mount 2 or 3 post ?
Old May 27, 2019 | 12:04 PM
The mounts are chrome with red inserts. And I have the 3 post driver side mount.
I didn’t know if you could use stock mounts for the swap to a b20. I’ll look into it.
Old May 27, 2019 | 12:49 PM
I think all you’ll need are mounts for an Integra.
90civicstdgold
Oct 28, 2010 01:58 AM
supafil25
Dec 26, 2009 09:59 PM
HAMOTORSPORTS
Jun 15, 2007 08:20 PM
MugenHonda
Jul 31, 2005 03:51 PM
